Trans troubles -fixed!ronvb 05-24-2006, 12:18 PM My 2001 Impala was getting a code 1811, it was shifting irregular and banging when put into reverse. As per a previous post from another member the code was a PCS-pressure control solenoid problem. My friend does transmissions, so he was able to repair with out pulling the trans out and replaced the PCS, another solenoid for the lock-up convertor and installed a fix type shift kit adjuster in the valve body. My friend said this is a very common probelm for this transmission. The car has not shifted this nice in over two years! Thanks to the forum members who led me to this fix. ronvb:grinyes: ysteve 05-29-2006, 07:52 PM Hi. Where are you from? Cause maybe i have the same problem(hard shifting, bang PtoDotR) I dont know what to think cause i dont have any SES light, i check alredy everything and still think my problem is missfire causing hard shift. And plus mechanics saying if no LIGHT then no problem(wich is stupid). Proabobly i have tranny problem. I am not mind to pay 100$ for diagnostic fee. By the way iam from NEW YORK (brooklyn) if you recomend me someone, i would be appreciated. ronvb 05-30-2006, 09:31 AM This problem does not throw a check engine light but it does set a trouble code without the light.You have to scan for trans codes.Cannot recommend friend as he is retired and only works when he wants to.:grinyes: ronvb vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
