1994 Intake Gasket Replacment
Google
Web AF
Aurora01
05-23-2006, 09:02 PM
I need to replace intake gasket on my 1994 Chevy 350 4X4 Can anyone post procedure from service manual?
password
05-31-2006, 03:56 PM
the procedure is pretty well outlined in the Haynes manual for that truck, invest the 20$
wafrederick
06-01-2006, 12:54 PM
It is real easy than the vortec 350s.Mark the distribitor although the timing is adjustable.To set the timing,you unplug a black wire with a tan stripe under the platic cover on the firewall.I do have a tip,if the new intake gaskets have the the supplied end gaskets,throw the end gaskets away and put a bead of RTV silicone instead in place of the end gaskets.The problem with the end gaskets are they split,cause an oil leak and you do not want to do the job twice.
Google
Web AF
