shift kit in a 93 1500 cheyenne truck????????blackcavy2002 05-17-2006, 11:04 PM I recently purchased a 1993 chevy cheyenne 1500 v8 5.7 liter 2wd pickup. I was told that there is a shift kit in it.My question is how hard should it shift from first to second?I could gas it and when it shifts with the automatic transmission it will chirp the wheels.Is it in wrong?bad transmission? Any help would be appreciated 2000CAYukon 05-18-2006, 02:55 AM I recently purchased a 1993 chevy cheyenne 1500 v8 5.7 liter 2wd pickup. I was told that there is a shift kit in it.My question is how hard should it shift from first to second?I could gas it and when it shifts with the automatic transmission it will chirp the wheels.Is it in wrong?bad transmission? Any help would be appreciated Do you know which kit is installed? I installed the Transgo Reprogramming Kit in a 4L60E car. The kit came with 3 washers for the 1-2 accumulator. This gave the installer the choice of mild to wild. With 3 washers, it will probably chirp going into 2nd every time. I went mild. I get nice 1-2 partial throttle shifts. If I floor it, it will chirp 2nd. The kit also improved the 2-3 and 3-4 shifts. You could pull the 1-2 accumulator and look to see how many washers are installed, if you can find out if they used a Transgo kit. I don't know enough about other brands of kits. In my opinion chirping 2nd every time will cause the tranny to wear out faster or even break. It really comes down to how you want the tranny setup. If you are not up to working on it, you could probably get a reputable tranny shop to soften the 1-2 shift. The pan has to be dropped but it is not major surgery. //2000CAYukon vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
