'98 5.7 Misfiring
Google
Web AF
98Z
05-17-2006, 07:39 PM
Last week the wife took my truck and when she returned, she said that they SES light had come on but had gone out not too long after. She said that the truck seemed to run fine but wanted me to know about the light. Yesterday, I took off (truck had sat one full day at least) and there was a bit of a stutter in the acceleration and it seemed to vibrate at low speeds. If I'd give it more throttle or accelerate harder, it didn't do it. I took it to the next town over (15 miles) and by the time I'd gotten there, the SES light was on again (not sure when it had come on). When I returned to town, I stopped in at a shop where I know a couple of the guys. I was lucky enough to get one of them to scan the computer (and clear the codes so the light would go off). I don't know if he actually told me the code number(s) that it gave, but he did tell me that it showed some misfires. He told me that the computer had recorded misfires on all 8 cylinder. He suggested that I check/replace the distrib. cap and check the plugs. The rest of the day and all day today the truck has acted just fine. There have been other times when I have experienced the hesitation and vibration but never had the light come on until recently.
Anyone else concur with this or have other ideas?
maxwedge
05-17-2006, 07:53 PM
Trust your mechanics here that is the basic starting point for that condition, how old, miles, are the plugs and wires?
98Z
05-17-2006, 09:15 PM
Maxwedge, I can't really answer that. I bought this truck a few months ago and haven't done much of anything to it. The plugs and wires both look fairly new. The wires are still clean and the metal on the plugs is clean and rust free. I can't imagine they are very old. The truck has 156K on it.
wafrederick
05-18-2006, 07:54 PM
It might be a worn out distribitor gear.The distribitor gear is a common problem,most dealers and auto parts stores stock them.It will cause a miss and I have seen that happen.Had one miss and put new set of sparkplugs that did not cure it.Finally pulled the distribitor out and the distribitor gear was worn out,had shiney spots.Installed a new distribitor gear, put the distribitor back in and ran fine after setting the distribitor with a scan tool.
chevrock22
05-19-2006, 04:20 PM
has the timing been checked?
MT-2500
05-19-2006, 07:01 PM
The timing is not adjustable on them.
But if the cam retard setting is way off it may cause engine running problems.
PS
Chevrock22
If you are so proud of that and want to use my quote make sure you put quoted from by MT-2500
I have copy rights on part of it but I will loan it to you as long as you state quoted from MT-2500
Or better yet post the hole thing and give Kenney rodgers the credit on his part.
MT
bracketshark
05-21-2006, 10:29 PM
I had this problem on a 97 model not long ago, I replaced plugs, wires, cap and rotor. Nothing made much differance, my problem was cured by adding Chevron with Techtron fuel additive (its in a black bottle) through a couple of tanks of gas. It seems the injectors plug somewhat if not cleaned after a period of time. If you've ever changed the intake gasket on one you can see how crappy the outside of the injectors get. I would think in your case with that many miles it has already been changed if not it will soon. By the way the timing sets with the distributor just as the older units only it can't be set with a light, it must be done with a scan tool that only the dealers have (in my area) the timing sets at + or - 2 deg. from 0, the computer will handle it from there, it will run up to 16 deg. out of timing but the check engine light will burn, + or - 2 deg. from 0 will not turn on the light. Good luck with your repair it probably won't be very much fun.
98Z
05-22-2006, 08:06 AM
After my mechanic friend reset the computer and I've run a full tank of gas through it after adding AC Delco Fuel Injector Cleaner ($10.00) to it, I have not yet experienced any of the aforementioned hesitation or sputtering and I haven't seen the SES light. For now I guess I'll just keep an eye on things and wait to see what happens. Thanks to all for the suggestions.
Dave
MT-2500
05-22-2006, 09:21 AM
The timing is not adjustable.
You can turn the dist all day and it will not change the timing.:grinyes: :rofl: :lol:
It only changes the cam retart which is a not a timing adjustment.
MT
chevrock22
05-22-2006, 02:49 PM
PS
Chevrock22
MT
Im not giving you credit this is there as a joke. And yes the timing can be set on the cams.
MT-2500
05-22-2006, 03:15 PM
THE IGN TIMING IS SET BY THE CRANKSHAFT SENSOR AND ADVANCED WITH PCM/VCM.
The cams and the dist has no part in it.
If you are going to use a quote from any of my post please quote the hole thing and state that is is my quote.
Otherwise it is copyright stealing.
MT
MT-2500
05-22-2006, 04:26 PM
Quote from chevrock22 signature= "It is time for you to fold and move on will you are ahead.
If not the moderator may be along to read you you your rights."
-MT-2500-
As you can see here them words were stolen copyright from my post.
If you are going to it do it right and post the hole thing and Kenney Rodgers may want part of the credit for that to.
http://www.automotiveforums.com/vbulletin/showthread.php?t=554929
Originally Posted by chevrock22why have respect for somone who has no idea what there talking about when they think they do.
chevrock22 it is Time to hang up the crap.
Like kenney Rodgers says there is a time to fold and a time to play.
You asked a Obenostic question and got several good answers that fits the question.
Good Luck
MT
If you are going to do it. Do it right the first time. Or you will have to undo it the next time. MT
bracketshark
05-22-2006, 10:23 PM
I know that when my timing was set at the Chevy dealership my friend employed there used the hand held unit and I myself turned the distributor until he said it was on ZERO. If you think the distributor will not affect timing go to one and turn one and see what happens. I've changed a dozen or so intake gaskets on vortec motors and know for sure you better put that distributor back in the exact location it comes from. You are correct in saying the computer will make adjustments as neccessary but it must be at ZERO PLUS OR MINUS TWO DEGREES OF DISTRIBUTOR [/B]TIMING PERIOD or the check engine light will come on until corrected. The engine will run up to 16 degrees out. If you want a real challenge get the GM distributor installation procedure and try to figure IT out, if distributor location didn't matter it wouldn't be so important where it was installed.
MT-2500
05-23-2006, 11:44 AM
I hate to break the news to you but the timing can not be adjusted on the newer v6 or v8 truck engines.
If you do not believe me get out your repair manual and read it.
I know I found it hard to believe to after adjusting the timing with the dist for 45 years but read the book and see.
You can turn the dist all day and not change the timing. It is preset and not adjustable from the crankshaft sensor.
Words of wisdom and experiance from the desk of MT-2500
And From the good book.
IGNITION TIMING
NOTE: Ignition timing is controlled by control module and is not adjustable.
CAMSHAFT RETARD OFFSET
NOTE:
Distributor can be adjusted to prevent crossfire.
Checking Retard Offset
1) With ignition off, connect a scan tool to Data Link Connector (DLC). Start engine and run until normal operating temperature is reached.
NOTE: Camshaft retard offset reading will NOT be accurate with
engine speed less than 1000 RPM.
2) Increase engine speed to more than 1000 RPM. Using scan tool, monitor Cam Retard Offset. If camshaft retard indicates zero degrees plus or minus 2 degrees, distributor is properly adjusted. Procedure is complete. If camshaft retard is not zero degrees plus or minus 2 degrees, see ADJUSTING RETARD OFFSET.
NOTE: Camshaft retard offset reading will NOT be accurate with engine speed less than 1000 RPM.
Adjusting Retard Offset
1) Turn ignition off. Slightly loosen distributor hold-down
bolt. Start engine. Increase engine speed to more than 1000 RPM. 2) Using scan tool, monitor Cam Retard Offset. To adjust for
a negative reading, rotate distributor counterclockwise. To adjust for a positive reading, rotate distributor clockwise.
3) Continue to adjust as necessary until zero degrees plus or minus 2 degrees is attained. Turn ignition off. Tighten distributor hold-down bolt to 25 ft. Ibs. (34 N.m.). Start engine. Increase engine speed to more than 1000 RPM. Using scan tool, verify camshaft retard offset adjustment.
The dist does need set but.
Turning the dist only sets the camshaft retard offset
It has nothing to do with the engine timing.
What it actually does is to center the dist rotor to the spark plug terminal on the dist cap.
If it does not fire when centered on the terminal it will cause a spark jump.
MT-2500
05-23-2006, 12:12 PM
I do have the procedure for setting the dist and it is not hard to figure out.
I have set a few hundred in my time.
And yes the setting mater but it has nothing to do with the ign timing.
http://files.automotiveforums.com/gallery/showphoto.php?photo=51302
Here is some more info from the repair manual on it.
IGNITION SYSTEM
Enhanced Ignition System
The enhanced ignition system consists of the VCM, distributor, ignition coil driver module, ignition coil and Camshaft Position (CMP) sensor. Ignition control and by-pass functions are controlled by the VCM.
* Camshaft Position (CMP) Sensor
CMP sensor is similar to CKP sensor. CMP sensor provides one pulse (1X signal) per camshaft revolution. VCM uses this signal in conjunction with the crankshaft position to determine which cylinder(s) are misfiring. * Crankshaft Position (CKP) Sensor
CKP sensor is located in the front engine cover. Air gap between sensor and target wheel is preset and is not
adjustable. Target wheel has 4 slots, 60 degrees apart, and is keyed to the crankshaft. Rotation of target wheel creates
a change in the magnetic field of the sensor which results in an induced voltage pulse. One crankshaft revolution will
result in 4 pulses (4X signal). Based on these pulses, VCM is able to determine crankshaft position and engine speed. VCM will then activate the fuel injector and provide spark to distributor.
* Distributor
Distributor assembly contains the Camshaft Position (CMP) sensor, cap, rotor and shaft. A Diagnostic Trouble Code (DTC) will set when distributor is installed a tooth off in
relation to the camshaft. Distributor is not serviceable. * Ignition Coil Driver Module
Module is mounted next to coil. VCM signals the ignition coil driver to turn on primary current to the ignition coil by pulling the IC line high (4 volts). The ignition control
driver turns the primary current on and off by applying and removing ground to primary winding. Module does not have a back-up function that would allow engine to run if IC signal is lost.
Ignition Timing Control
Ignition spark timing and ignition dwell time are entirely
controlled by the PCMNCM. The PCMNCM monitors information from various engine sensors, computes the dissjred spark timing and dwell, and firing of the ignition coil via IC line to the coil driver.
chevrock22
05-23-2006, 03:53 PM
Isnt this guy pathetic thats why i get all the credit for my signature.ha!
MT-2500
05-23-2006, 04:46 PM
This siginture was stolen from MT-2500
Good Luck
MT
bracketshark
05-23-2006, 10:03 PM
Ok you win, I had to have my distributor phased in and that actually does make good reasoning. I agree completely that the computer is in control of all timing functions of a running 96 and later model chevy v8 engines. I used to do this on my drag car when running a crank trigger, we drilled a hole beside #1 plug wire in the cap and used the timing light to set this. Just out of curiosity what kind of work are you in Mr. MT 2500? My connection at the dealership in the service dept. with 19 years of service said he had only had maybe a dozen new installations of vortec distributors. I mean they are only used from 96 thru I think 99, just 4 years thats a lot of installs, the hundreds you spoke of must have been in a very large service dept.. Anyway thanks for setting me straight, and just so we're clear you were also right when you said " The timing is not adjustable. You can turn the dist all day and it will not change the timing.
It only changes the cam retart which is a not a timing adjustment."
If you turn the distributor the engine will not run after the cam retard is more than ~16 deg. out. I like distributor phasing better than cam retard or retart (as you said) whichever it is. Thanks again for your knowledgable input and I look forward to reading more of your lessons. Regards, bracketshark
MT-2500
05-23-2006, 11:19 PM
10-4 on the dist. and timing
And 10-4 on dist phasing. That is actually what they call cam retard. I never could see why they called it cam retard.
I might have said replace dist but I should have said remove and install them.
Mostly with a intake gasket job. I average at least one intake job a week where you have to remove and install dist almost ever since they have been out 52 a year time 8-9 years adds up.
Along with a few valve or headgasket jobs.
I have replaced a few dist. usually for a broken dist cap hold down ear over the years.
I have 20 years dealership line mechanic experiance before they had techs.
and I have 25 years experiance operating my own repair shop.
MT
GMMerlin
05-24-2006, 06:28 AM
If you do not have anything intellegent to add here, move on.
chevrock22
05-24-2006, 03:40 PM
ya, that was a fun day when the moderator made you look like an idiot.
Good Luck
MT
blazee
05-24-2006, 04:59 PM
Just couldn't let it go, could you? Well you'll have plenty of time to think about it. :wave:
GMMerlin
05-24-2006, 08:49 PM
Damm..you stole my banage...I guess I'll wait til he comes back then ban him again:iceslolan
Google
Web AF
