Breaking in a new Headgasket00Buck 05-17-2006, 06:02 PM Just finished replacing my headgasket on the 5.7 burb. I have been letting it warm up to temp then slowly driving it around the neighborhood. Do I need to do any kind of engine break-in procedure? How soon should I change the oil? Also I have 20 gallons of fuel that is a year old in the tank, is this a problem? Thanks for all the help. maxwedge 05-17-2006, 07:32 PM Just don't overheat it of course, dump the fuel asap. If you didn't change the oil right after the repair, do it. 00Buck 05-18-2006, 10:32 AM Just don't overheat it of course, dump the fuel asap. If you didn't change the oil right after the repair, do it. The oil was changed when I put the heads back on. When you mean " dump the fuel" does that mean siphon it out or burn it through the engine. If I burne it through the engine should I add any kind of fuel treatment to it?? thanks for the help. maxwedge 05-19-2006, 07:14 PM The oil was changed when I put the heads back on. When you mean " dump the fuel" does that mean siphon it out or burn it through the engine. If I burne it through the engine should I add any kind of fuel treatment to it?? thanks for the help. Well I would try and get as much out as possible, could be pretty stale and may have accumulated some water. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
