Valve adjustmentcbbond 05-15-2006, 10:10 PM What should come first with your standard 1600cc (VW Beetle) tune-up? Valve adjustment, then Oil change (or vice versa)? Thanks, Casey BoatCop 05-15-2006, 10:55 PM What should come first with your standard 1600cc (VW Beetle) tune-up? Valve adjustment, then Oil change (or vice versa)? Thanks, Casey Oil change can be done at any time. As far as the rest of the tune-up: 1) Valve adjust (dead cold, let it sit overnight) 2) Set points 3) Static timing 4) carb adjust (warmed up) 5) Final timing vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
