s10 4x4 problem
tintle1
05-15-2006, 10:03 AM
i recently purchased a 1991 s10 4x4 and when i engage the transfer case, no power is supplied to the front end. Any suggestions as to what the problem is would be appreciated.
OverBoardProject
05-15-2006, 01:40 PM
Welcome to Automotive Forums :cheers:
And congrats on your new purchase.
Read this thread first, and see if it helps you
http://www.automotiveforums.com/vbulletin/showthread.php?t=498812
it shows how to change the most common problem, but there are a few more things that it can be.
olddog1946
06-02-2006, 11:24 AM
99 out of 100 times you'll probably find that one of the vacuum lines to the transfer case is bad.Most likey one got hot and burned through..every older one I have come across has had that problem.
