Alternator/Generator Test
Google
Web AF
trcape
05-14-2006, 11:07 PM
I have a 1974 Volkswagen Beetle that refuses to idle. I've replaced the gaskets, seals and screws on the carberator. When I choke it heavily it will idle roughly. Not sure if this is related but I attempted to test the Generator and the output voltage is around 2 - 3 volts when running and 12 volts when turned off. Do I have a bad Generator?
brussell
11-17-2008, 11:28 PM
it sounds like you generator is shorting and is trying to turn backwards take fan belt off and start motor and see if it will idle
Google
Web AF
