396 In a Caprice?
Google
Web AF
br200es
07-23-2002, 04:51 PM
Recently I bought an 87 305 cid Caprice for $30, all it needed was a transmision. Once I took the old tranny out, I was thinking for $30 this would be a good project car. I have a 396 out of a wrecked Chevelle. Would the 396 fit into the Caprice and bolt to the thm700r4. If it would go into the Caprice with that tranny, what other sort of problems should I expect?
Thanks for any help.
Steve
-The Stig-
07-30-2002, 09:07 PM
aha sweet idea.
Yes a 396 Big Block will bolt up to a 700R4 with no problem. All you may have to is fabricate/buy new motor mounts.
I garuantee nothing. But i wish you the best of luck!
CRXforever
11-07-2002, 02:09 AM
you will have some problems with torq on the tranny th700r4 cant take that much torq from big blocks other than that you would have no problems
Boxchevyondubz
08-19-2003, 03:12 AM
You'll definately have torque problems. If you aren't planning on changing the rear end, i wouldn't proceed.
kj598bbc
03-20-2009, 12:15 AM
You absolutely do not have to buy or fabricate any mounts, everything bolts up !!!! DO IT !!!! My 79 caprice aerocoupe has a mild 468 big block, 700r4, and im installing the posi and 4.10 gears outta my 77 aerocoupe when the weather brakes here in chicago.:banghead:
96capricemgr
03-28-2009, 10:19 AM
The 700 can be a great tranny if built well, can be a giant POS if built badly.
A 396 might make less torque than a stock LT1, unless it is a wild engine you should have no problem getting a 700 to live behind it.
Google
Web AF
