Hand-brake lampdingo2 05-13-2006, 11:58 AM Anyone has a clue about this strange problem i have:: With the engine switched off, but the ignition on,,when i release the hand-brake,,the lamp in the dashboard dims,,but does not extinguish completely. Then when i turn on the engine,,it goes out completely. I am sure that it wasn't working this way before...i was thinking about a bad earth....what do you think?? Jay! 05-13-2006, 01:01 PM Some models are set so that BRAKE light will come on when your brake pads are wearing thin, and therefore your brake fluid reservior is low. It's a warning for you to check (and replace if needed) your brake pads. My 2000 Impreza did this fairly recently. I don't know if your 1996 is set up to work the same way. Check your brakes, just to be safe. freakray 05-13-2006, 04:29 PM I agree with Jay, check your pads, also check your brake fluid level in case you have a leaking brake line. dingo2 05-14-2006, 01:37 PM i've checked the fluid its full, and the front brake pads are almost new. Should i check the rear drum shoes? Jay! 05-14-2006, 03:49 PM What does it do when you apply/release the hand brake with the engine running? freakray 05-14-2006, 05:24 PM After replacing the shoes, did you bleed the lines? dingo2 05-14-2006, 06:13 PM Applying/releasing the handbrake with the engine running, the dashboard light works normally. It is with the engine turned off, that the lamp stays dimly lit when releasing the handbrake. I have tried disconnecting the wires that go to the fluid reservoir but the lamps stays half lit just the same. No i didnt bleed the system as the brakes seem to be working normally........... Jay! 05-24-2006, 01:10 PM Here's a long shot: Do you have a brake light burnt out? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
