HELP 97 crown vic high beams stay on
mouchie
05-07-2006, 10:29 AM
hi my high beams stay on,i did turn them on they just came on.the indicator light on the dash come on when i turn on the lights.and my run light don t work .help:banghead:
ModMech
05-07-2006, 10:45 AM
Sounds like the high/low beam switch died. It is an integral part of the MFS (MultiFunctionSwitch) aka: Turn signal switch, so you have to replace the whole thing.
mouchie
05-07-2006, 11:48 AM
hi thank 4 the help is it a big job or take to a pro
ModMech
05-07-2006, 03:13 PM
Easy job, 15 minutes. The only "special" tools you need are a set of "Torx" screwdrivers.
mouchie
05-07-2006, 08:21 PM
Hi it in the steering column right ? under the cover i hope
ModMech
05-07-2006, 11:11 PM
Yup. three screws and the cover is loose (you cannot remove the upper cover because the shifter runs thru it, but it does not matter).
mouchie
05-08-2006, 06:54 PM
thanks 4 all the help i will let u no how it work out....??
reekor
05-08-2006, 08:43 PM
If it's a Canadian model with drl, disconnect the daytime-driving-lights harness on the rad support.
mouchie
06-03-2006, 11:04 AM
hi were is the relay 4 the day time lights
