BA Falcon?!?Jimbo_Jones 07-19-2002, 11:07 PM recently i was talking to a 'ford owning' friend of mine and he was telling me about fords new model... the BA, according to ford it has one of the most powerful 6's ever built (inline or V... i dont know) i was wondering is anyone had specs of this car, news, knowledge anything... GregLocock 08-01-2002, 08:47 PM It is the straight six with a DOHC. Apart from that you'll just have to wait and see. Oh, and statement of the obvious : "one of the most powerful sixes ever" is a completely meaningless phrase. Cheers Greg Locock Ssom 08-10-2002, 06:15 AM uuuuggggggghhhhh..........BA Falcon = :apuke: the six is pointless...... The Mondeo after all, is a far more complete car:mad: P Stewart 08-10-2002, 07:00 AM Heres a link to where you can find some pictures of the BA. http://pub59.ezboard.com/ffordsperformancefalconsforumfrm2.showMessageRange ?topicID=136.topic&start=1&stop=30 replicant_008 08-26-2002, 03:21 AM Anyone heard anything about drivetrain apart from the XR6 possibly going VSS, DOHC and turbo? I suspect V8 is 4.6 and 5.3 SOHC but anyone seen any details? Ssom 08-28-2002, 05:54 AM Originally posted by replicant_008 Anyone heard anything about drivetrain apart from the XR6 possibly going VSS, DOHC and turbo? I suspect V8 is 4.6 and 5.3 SOHC but anyone seen any details? Nope Ford are staying pretty tight-lipped until the launch :( Judge 08-28-2002, 06:23 AM Originally posted by Moss1O6GTi uuuuggggggghhhhh..........BA Falcon = :apuke: I think its improved alot over the AU, with the front lights and all..... P Stewart 08-30-2002, 07:24 AM I have been lucky to go to the Broadmedows Ford plant and have sat in most of the BA models. And, No they are not using the 4.6L V8. They will be using the 5.4L one though and the XR6 will be turbo charged to 220+kWs which should allow it to do 0-100km/h in the low 6s or 5s. Inside, it is very european. Very well put together and luxurious and about the base engine. Yes, it is a DOHC, 24v I6 that will produce a lot more than the current 157kWs and a lot more torque. ak69 09-04-2002, 01:18 PM Well guys,i put my money down today for the new BA falcon There is a big fuss down here in australia about this car,i might as well test and trash it out for myself! Will soon be driving it once it it given to me! replicant_008 09-05-2002, 01:25 AM Base Engine 4.0 litre I-6 182kw 380Nm Features upgrade to DOHC, Dual VCT (ie on both intake and exhaust cams with 60 degrees of variation), 24 valve (4 valves per cylinder), coil on plug ignition, chain drive for cams, drive-by-wire throttle Base V8 (extra cost option) 5.4 litre V8 (Ford Modular V8) 220kW 470Nm Features SOHC per bank, 24 valve (3 valves per cylinder), alloy heads XR6 Turbo 4.0 litre I-6 Turbo (about 6psi of boost) 240kW, 450Nm Features upgrades as per base 6 and Garrett GT40 turbo, 24 valve (4V), 8.7:1 compression Hi Performance V8 V8 (no displacement provided) 260kW 500Nm Torque Dubbed 'Boss' 260 - V8 with 32 valves - no other details replicant_008 09-05-2002, 01:26 AM Incidentally Boss 260 not available until early 2003... Ssom 09-16-2002, 04:29 AM Originally posted by replicant_008 Base Engine 4.0 litre I-6 182kw 380Nm Features upgrade to DOHC, Dual VCT (ie on both intake and exhaust cams with 60 degrees of variation), 24 valve (4 valves per cylinder), coil on plug ignition, chain drive for cams, drive-by-wire throttle Base V8 (extra cost option) 5.4 litre V8 (Ford Modular V8) 220kW 470Nm Features SOHC per bank, 24 valve (3 valves per cylinder), alloy heads XR6 Turbo 4.0 litre I-6 Turbo (about 6psi of boost) 240kW, 450Nm Features upgrades as per base 6 and Garrett GT40 turbo, 24 valve (4V), 8.7:1 compression Hi Performance V8 V8 (no displacement provided) 260kW 500Nm Torque Dubbed 'Boss' 260 - V8 with 32 valves - no other details I want an XR6 after reading the latest Wheels :licker: New&Improve 10-09-2002, 01:44 AM The new and Improved XR R32's Kick ass 10-22-2002, 05:33 AM The XR6 turbo(which only pumps out 6 psi) has 240kw @ 5200RPM and 450Nm @2000 - 4500RPM Bore and stroke is 92.26mm x 99.31mm weight to power is 6.96kg/kw specific power is 60kw per litre 8.7:1 compression and it costs $43,965 1/4 mile run is 14.14 and 0-100km/h is 5.91 Go team 12-09-2002, 01:46 AM wait untill they bring the BA XR8 not XR6 i heard that THe XR8 will have over 290kw thats pretty fast and then BA ute oh my god this is so cool vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
