Why Won't It Start?!
Google
Web AF
lifelongslacker
04-26-2006, 11:16 PM
I have a 96 cav 2.2L that I put a new head gasket on recently. All the plucs are getting spark, the compression is good, the fule injectors are working and all the valves have been timed.
So why wont it turn over?
Any ideas?
I tried getting the starter tested, came back fine. Tomorrow I will check the voltage getting to the starter.
Other than that, ANY input would be appriciated.
KustmAce
04-27-2006, 12:59 AM
did you check the battery?
lifelongslacker
04-27-2006, 10:22 PM
Checked the battery, full charge. The funny thing is sometimes the engine won't even crank, like it is seezed up. The starter will keep pulling but the engine will not move.
boarder_punk
04-27-2006, 10:32 PM
Sounds like a wiring issue, check for grounds and shorts in the wiring to the starter.
Google
Web AF
