Codes 12 34 51
View Full Version : Codes 12 34 51 Codes 12 34 51 xgrungepedalx 04-24-2006, 09:12 PM sidewayzS13 04-24-2006, 10:14 PM as for the codes im not sure. that sucks that you got frame rust though thats a common problem happens all the time on them up north. that aspect of the car is kinda shitty and for the body parts well they are normally prety easy to find whats rusted on the body? my guess is if you have a hatchback then the hatch is rusted that always happens to all of them w/ spoilers. slidestar just did a fix on his hatch. but unless you replase the rusted part its basically always going to be in there. zdude 04-24-2006, 10:28 PM hmmm...i had a 89 from wisconsin and it had almost no rust, although the body was a little abused. cant remember where the knock sensor is, but im sure someone will come along with your answer. isn't it most commonly the first cylinder injector going bad because its first on the fuel rail? i cant remember. gosh the number of times i frequent these forums gets fewer and fewer!! Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
