93 S-10 4.3L spark plugs
nodollaznosense
04-23-2006, 07:44 PM
Man these are in some tricky ass spots at first glance, anything have to be removed to get to them? thanks
gmtech79
04-23-2006, 08:00 PM
Go through the fender wells with an extension and/or a swivel. You may need to remove the air cleaner assembly for the left bank. No need to remove anything else, even the steering shaft.
MT-2500
04-23-2006, 08:59 PM
Piece of cake/gravy gob after you have do a few 100 of them.
Like said go threw the fender wells.
And on the center one on drivers side.
Get a good plug socket with a wrench head on it and use a box end wrench on plug socket.
And make sure you use the good OEm type AC-Delco plugs or you will be sorry you do not.
MT
MT
RahX
04-23-2006, 11:20 PM
^^^^ what he said. Bosch platinums might cost more and have a fancy gimmick but they SUCK.
jsgold
04-27-2006, 08:12 PM
Just curious, anyone have any experiance with Autolite platinum plugs? I used them and Autolite wires since the a-holes at Advance quit stocking them here. I have a poor idle and am wondering if these things may be a problem. Slight miss, have checked everything I could think of. Had not heard much on Autolites mentioned on here but have seen AC Delcos recommended as only choice.
dmbrisket 51
04-28-2006, 12:28 AM
autolites are a no no in our blazers, AC Delco plats, if you have to go to a better parts store to get them then so be it
blazee
04-28-2006, 05:18 PM
AC Delcos are the most reliable. I've got 60,000 miles on my autolite platinum plugs and wires. I have not had any problems with them, and my engine runs great. I've heard that there's lower quality control with Autolites, and that you're more likely to get a bad plug than with AC Delco. You shouldn't have any problems as long as you're lucky enough to get a good set. If you got a bad plug, it could cause miss that you're experiencing.
spasticone
05-04-2006, 09:31 AM
I'd like to throw in my vote for bosch platinums sucking. They are no no's in higher mile cars as they tent not to clean themselves well. I was parts manager at a performance vw/honda shop for a few years and they HATED platinums. constant cause of missfires in v-6 chevy's too.
jsgold
05-04-2006, 10:03 AM
Thanks for the input. I will change out both plugs and wires first chance I get to see if this helps. My truck gets decent mileage, shows no signs of cpi trouble, and I have checked every other component on it to try and find the misfire, which occurs at idle ONLY, so maybe this is the problem.
RahX
05-04-2006, 08:46 PM
Really any plug BUT Bosch should work out pretty good. AC Delco/NGK/Denso are probably my top 3 favorite plugs to use.
