Missfire piss me offysteve 04-22-2006, 04:27 PM Hi guys. Hi bnaylor3400. Listen, today i check EGR and everything is fine, i cant find what from missfire. Last sunday you tolld me that can be EGR, today i check everithing and stiil having it. I have another two things wich can cause it. How i can check injectors and coils. I tried two times to puting those treatment inside of the tank. Maybe they cleand out alredy. What else it could be? Thanks. BNaylor 04-24-2006, 08:40 AM Hi guys. Hi bnaylor3400. Listen, today i check EGR and everything is fine, i cant find what from missfire. Last sunday you tolld me that can be EGR, today i check everithing and stiil having it. I have another two things wich can cause it. How i can check injectors and coils. I tried two times to puting those treatment inside of the tank. Maybe they cleand out alredy. What else it could be? Thanks. On a 3.4 checking the fuel injectors is not that easy. Normally you can run a noid light test to check injector pulse from the PCM and also, check the injector coil resistance with a multimeter. Problem is you'll have to remove the upper intake manifold (UIM) to do that for access. The noid light test will be impossible with UIM removed. Once the UIM is removed the fuel rail and injectors are accessible for troubleshooting and inspection. Check the condition of the fuel injector o-rings if you decide to remove the fuel injectors. The ignition control module (ICM) can be tested at Autozone. Coils can be swapped around. tractorboy 04-24-2006, 04:43 PM deid you check your fuel pressure ? ysteve 04-24-2006, 06:51 PM No i never check the fuel pressure. Do you guys think i can remove UIM and check injectors by my self, or it risky. How i can check fuel pressure, and what can cause the problem regulator or pump. Cause i tryed injector cleaner two times. Maybe injectors already clean, maybe something else. BNaylor 04-24-2006, 07:06 PM No i never check the fuel pressure. Do you guys think i can remove UIM and check injectors by my self, or it risky. How i can check fuel pressure, and what can cause the problem regulator or pump. Cause i tryed injector cleaner two times. Maybe injectors already clean, maybe something else. I recall someone recommended doing that in your other posts. But on the 3.4L see pic below. The gauge is hooked up to the Schrader valve on the rear fuel injector rail by the power steering pump. Not sure of your fuel pressure specs but on my Alero with 3.4L it reads nothing less than 55 psi in fuel pump prime position (ignition run) and while idling with vacuum disconnected on the fuel pressure regulator. http://i5.photobucket.com/albums/y186/lizzywiz/alerofp.jpg ysteve 04-24-2006, 08:31 PM Where i can get that gage? And engine suposed to be on or off? JJ Newel 04-24-2006, 09:54 PM You can get it at autozone, pepboys, and other parts strores for about $40. Actron makes this gauge. And it will work on your vehicle even though the package says "For vehicles 1996 and under". ysteve 04-24-2006, 10:11 PM Guys actualy i am AC TECHnician and having almost the same gage and it showd me 51 PSI. I dont know if its enought or not? JJ Newel 04-24-2006, 10:38 PM yea it's enough here are the specs for the fuel pressure (engine not running, key on). 3.4 L : 52 to 59 psi 3.8 L : 53 to 59 psi BNaylor 04-25-2006, 01:39 AM Guys actualy i am AC TECHnician and having almost the same gage and it showd me 51 PSI. I dont know if its enought or not? How did you run the test? Was it in the fuel pump prime position (ignition run not start)? Or was engine running at idle? Also you will get different readings wth vacuum on or off at the fuel pressure regulator (FPR). So run the test with the following parameters and post results: Ignition on, not start (Fuel Pump Prime) Engine running at idle with vaccum line on at the FPR. Engine running at idle with vacuum line off at the FPR. JJ Newel 04-25-2006, 06:46 PM these specs are for the fuel pump prime position. ysteve 04-25-2006, 07:02 PM Yeah ignition on engine off showed me 51, and i tried without vacuum hose it showed 60. So looks like the problem is not fuel. ysteve 04-25-2006, 07:10 PM Guys the only couple things left to check its MAF,INjectors. How can i do that cause i really dont wanna spend money right now. I wanna move from new york to ohio and i really short with money. Look what i found, but i cant check those bastards by my self, maybe its not it. Another guy told me what is the gap on your plugs. I never checkd the gap , i just bought ACdelco and trow it in. A/T - Shift/Driveability Concerns/SES Lamp ON Bulletin No.: 04-07-30-013A Date: January 25, 2005 INFORMATION Subject: Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On as a Result of the Use of an Excessively/Over-Oiled Aftermarket, Reusable Air Filter Models: 2005 and Prior GM Cars and Light Duty Trucks 2005 and Prior Saturn Models Supercede: This bulletin is being revised to add additional model years and to clarify warranty coverage. Please discard Corporate Bulletin Number 04-07-30-013 (Section 07 - Transmission/Transaxle). http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OB0~P3R0H~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/34856143/42063449/57413322/112163062/111809841/111818979 The use of an excessively/over-oiled aftermarket, reusable air filter may result in: ^Service Engine Soon (SES) Light On ^Transmission shift concerns, slipping and damaged clutch(es) or band(s) ^Engine driveability concerns, poor acceleration from a stop, limited engine RPM range The oil that is used on these air filter elements (http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OD~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/34872087) may be transferred onto the Mass Air Flow (MAF) sensor causing contamination of the sensor. As a result, the Grams per Second (GPS) signal from the MAF may be low and any or all of the concerns listed above may occur. When servicing a vehicle with any of these concerns, be sure to check for the presence of an aftermarket reusable, excessively/over-oiled air filter. The MAF, GPS reading should be compared to a like vehicle with an OEM air box and filter under the same driving conditions to verify the concern. The use of an aftermarket reusable air filter DOES NOT void the vehicle's warranty. If an aftermarket reusable air filter is used, technicians should inspect the MAF sensor element and the air induction hose for contamination of oil prior to making warranty repairs. Transmission or engine driveability concerns (related to the MAF sensor being contaminated with oil) that are the result of the use of an aftermarket reusable, excessively/over-oiled air filter are not considered to be warrantable repair items. Fuel System - Possible MIL ON/Driveability Issues Bulletin No.: 03-06-04-030A Date: June 24, 2004 TECHNICAL Subject: Multiple Driveability Symptoms Due to Clogged Fuel Injectors (Clean Injectors) http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OB0~P4R0H~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/34856143/42063449/56955374/108162429/108593052/108593053 Models Supercede: This bulletin is being revised to update the procedure, models and model years. Please discard Corporate Bulletin Number 03-06-04-030 (Section 06 - Engine). Condition Some owners may comment on driveability symptoms of long or hard starts, chuggle, rough idle and light or intermittent misfire. The malfunction indicator lamp (MIL) may also illuminate. Cause Due to various factors, the fuel injectors may become restricted. Extensive testing has demonstrated that fuel related issues are the cause of clogged injectors. At this point, no specific fuel, fuel constituent, or engine condition has been identified as causing the restriction. The restriction causes the engine to operate at a lean air fuel ratio. This may either trigger the MIL to illuminate or the engine to develop various driveability symptoms. Correction Fuel injector restrictions, deposits, can be cleaned on the vehicle using the following procedure. Under NO circumstances should this procedure be modified, changed or shortened. Note: The recommended mixture amount of GM Top-Engine Cleaner has been increased from 5% used in prior procedures to 10%. This increase was implemented to improve the effectiveness of the injector cleaning procedure. Follow the cleaning procedure carefully to minimize the risk of fuel system damage. Testing has demonstrated that exceeding the 10% cleaning solution concentration does not improve the effectiveness of this procedure. GM Top-Engine Cleaner is the only injector cleaning agent approved for use with General Motors fuel system components. Other injector cleaners may cause damage to plastics, plated metals or bearings. General Motors has completed extensive laboratory testing of GM Top-Engine Cleaner, and can assure its compatibility with General Motors fuel system components, as long as the cleaning procedure is followed correctly. Important: This bulletin recommends the use of pre-measured containers of GM Top-Engine Cleaner, P/N 12346535, - U.S. USAGE ONLY. Pre-measured containers eliminate the need to measure the amount of GM Top-Engine Cleaner being added to the J 35800-A, injector cleaning tool. In Canada, use P/N 992872. It will be necessary to measure and dispense Top Engine Cleaner into the J 35800-A, injector cleaning tool. Injector Balance Test The following tools, or their equivalent, are required: ^J 35800-A Fuel Injector Cleaner^J 37287 Fuel Line Shut-off Adapter^J 42964 Fuel Line Shut-off Adapter^J 42873 Fuel Line Shut-off Adapter^Four pre-measured GM Top-Engine Cleaner Containers, 24 ml (0.812 oz) each, P/N 12346535, U.S. USAGE ONLY. In Canada, use P/N 992872, 443.6 ml (15 oz) bottle. It will be necessary to measure and dispense 48 ml (1.6 oz) of Top Engine-Cleaner into the J 35800-A, injector cleaning tool twice during this procedure. See Injector Cleaning Procedure below for further information. Important: Analysis of returned Multec II injectors indicate that terminal fretting corrosion may also be responsible for the conditions described in this bulletin. Since fretting corrosion (microscopic in nature) is nearly impossible to detect in the field, the following steps should be taken to ensure that fretting corrosion is not an issue before performing any additional diagnostics. Fretting is a term used to describe a tiny rubbing motion that occurs between two surfaces. Fretting corrosion refers to a build up of insulating, oxidized debris that forms on electrical connections due to a fretting action at the contact points. Injector vibration, engine vibration, and electrical harness movement are contributors to the fretting motion. Depending on how large the build-up of oxide is will determine how drastic the effect will be on the injector circuit. Worst case is a total loss of continuity in the connection resulting in P0200 (Injector Circuit Fault) and P0300 (Misfire) codes being set. If the oxides create a high resistance circuit, insufficient current will be available to properly open the injector, resulting in unstable fuel delivery and ultimately a P0300 DTC. High resistance in the circuit will not necessarily set a DTC P0200. Keep in mind that a connection with fretting corrosion is unstable. Since movement causes fretting, any vibration may create a condition where the connection varies from an open circuit, to a high resistance connection, to a good connection. Important: Unless intermittent mis-fire due to fretting corrosion is suspected when servicing 3.1 L and 3.4L engines, skip steps 1 through 4. Steps 1 through 4 may be performed at a future date when the upper intake is removed. When servicing 2.8L, 3.5L or 4.2L engines (VINs 8, 6, S - RPOs LK5, L52, LL8) skip steps 1 through 4 unless replacing injectors. 1.Disconnect one injector electrical connector. 2.Apply a small amount, about the size of a BB, of dielectric grease, P/N 12377900 (in Canada, P/N 10953529) to the female terminal. Be sure to cover both cavities. 3.Reconnect electrical connector to injector. 4.Repeat steps 1 through 3 for all remaining injectors. 5.Using the Tech 2(R), perform an injector balance test using the procedure in the appropriate Service Manual. Use the Tech 2(R) to select each individual injector. Record the pressure drop of each injector on the repair order. http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OB0~P4R0H~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/34856143/42063449/56955374/108162429/108593052/108593054 http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OB0~P4R0H~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/34856143/42063449/56955374/108162429/108593052/108593055 Important: Technicians must record the results of all injector balance tests and keep them with the repair order. For your convenience, the bulletin has a worksheet shown for recording the test results. http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OB0~P3R0H~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/34856143/42063449/56955374/108162429/108593052/108593056 http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OB0~P3R0H~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/34856143/42063449/56955374/108162429/108593052/108593057 6.Subtract the lowest pressure drop, leanest injector, from the highest pressure drop, richest injector. If there is greater than or equal to a 20 kPa difference between the lowest and highest pressure drop, then the fuel injectors may be the cause of the driveability symptom. See the example tables shown to determine if cleaning is appropriate. 7.If there is less than a 20 kPa difference, between the highest and lowest fuel pressure (http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OD~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/58828685) drop, the fuel injectors are operating properly and further Service Manual diagnostics should be performed on the vehicle. All diagnostic time should be added to the appropriate labor operation for the repair performed and not to injector cleaning. Although the pressure drop is greater than or equal to 20 kPa, cylinder 2 stands out as being rich when compared to the other injectors. Do not clean the injectors. Replace injector number 2. Charge time to labor operation J5650. Important: When replacing injectors be sure to add dielectric grease to injector electrical connectors. The pressure drop is greater than or equal to 20 kPa. Injectors 1 and 3 appear to be lean when compared to injectors 2, 4, 5 and 6. Clean and re-test pressure drop. If cleaning does not restore flow on injectors 1 or 3, replace the detective injector or injectors as necessary. Charge time to labor operation J5650. Injector Cleaning Procedure Note: GM Top-Engine Cleaner is the only injector cleaning agent recommended. DO NOT USE OTHER CLEANING AGENTS, AS THEY MAY CONTAIN METHANOL WHICH CAN DAMAGE FUEL SYSTEM COMPONENTS. Under NO circumstances should the GM Top-Engine Cleaner be added to the vehicle fuel tank, as it may damage the fuel pump and other system components. Do not exceed a 10% cleaning solution concentration. Higher concentrations may damage fuel system components. Testing has demonstrated that exceeding the 10% cleaning solution concentration does not improve the effectiveness of this procedure. During this procedure, you will need a total of 960 ml (32.4 oz) of cleaning solution (10% Top Engine Cleaner/90% Regular Unleaded Gasoline). That is two tanks of solution for the J 35800-A Fuel Injector Cleaner Tank. Other brands of tools may have a different capacity and would, therefore, require more or less tanks to complete the procedure. You must use all 960 ml (32.4 oz) of solution (10% Top Engine Cleaner/90% Regular Unleaded Gasoline) to insure complete injector cleaning. Important: Vehicles with less than 100 miles (160 km) on the odometer should not have the injectors cleaned. These vehicles should have any out of specification injectors replaced. 1.For U.S. dealers, empty 2 pre-measured GM Top-Engine Cleaner containers, 24 ml (0.812 oz) each, P/N 12346535, into the J 35800-A, injector cleaning tank. For Canadian Dealers, measure and dispense 48 ml (1.62 oz) of Top-Engine Cleaner, P/N 992872, into the J 35800-A, injector cleaning tank. If you are using any other brand of tank, you will need a total of 96 ml (3.24 oz) of Top-Engine Cleaner mixed with 864 ml (29.16 oz) of regular unleaded gasoline. 2.Fill the injector cleaning tank with regular unleaded gasoline. Be sure to follow all additional instructions provided with the tool. 3.Electrically disable the vehicle fuel pump by removing the fuel pump relay and disconnecting the oil pressure switch connector, if equipped. 4.Turn the ignition to the Off position. 5.Relieve fuel pressure (http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OD~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/58828685) and disconnect the fuel feed and return lines at the fuel rail. Plug the fuel feed and return lines coming off the fuel rail with J 37287, J 42873 or J 42964 as appropriate for the fuel system. 6.Connect the J 35800-A to the vehicle fuel rail. 7.Pressurize the J 35800-A to 510 kPa (75 psi). 8.Start and idle the engine until it stalls, due to lack of fuel. This should take approximately 15-20 minutes. 9.Turn the ignition to the Off position. 10.Refill the J 35800-A injector cleaning tank per steps 1 and 2. 11.Start and idle the engine until it stalls, due to lack of fuel. This should take approximately 15-20 minutes. 12.Turn the ignition to the Off position. 13.Disconnect J 35800-A from the fuel rail. 14.Reconnect the vehicle fuel pump relay and oil pressure switch connector, if equipped. 15.Remove the J 37287, J 42873 or J 42964 and reconnect the vehicle fuel feed and return lines. 16.Start and idle the vehicle for an additional 2 minutes to ensure residual injector cleaner is flushed from the fuel rail and fuel lines. 17.Repeat Step 5 of the Injector Balance Test and record the fuel pressure (http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OD~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/58828685) drop from each injector. 18.Subtract the lowest fuel pressure (http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OD~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/58828685) drop from the highest fuel pressure drop. If the value is less than 15 kPa, no additional action is required. If the value is greater than or equal to 15 kPa, replace the injector assembly with the lowest fuel pressure drop. Follow injector replacement procedures outlined in the appropriate Service Manual Information for the vehicle. Repeat balance test to ensure that all injectors fall within 15 kPa. 19.Add one ounce (30 ml) of Fuel System Treatment, P/N 12345104 (Canada P/N 89020804), to the vehicle fuel tank for each gallon (3.78 L) of gasoline estimated to be in the fuel tank. Instruct the customer to add the remainder of the bottle of Fuel System Treatment to the vehicle fuel tank at the next fill-up. 20.Advise customer to change brands of fuel and to add GM Fuel System Treatment at every oil change. Regular use of GM Fuel System Treatment should keep the customer from having to repeat the injector cleaning procedure. 21.Road test the vehicle to verify that the customer concern has been corrected. http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OB0~P3R0H~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/34856143/42063449/56955374/108162429/108593052/108593058 Parts Information Parts are currently available from GMSPO. Warranty Information http://www.alldatadiy.com/alldata/AFI~V6558764~C37398~R0~OB0~P4R0H~N/0/89012112/94694975/94694986/94694990/34853741/100411974/34853743/34856143/42063449/56955374/108162429/108593052/108593059 For vehicles serviced under warranty, use the table. BNaylor 04-26-2006, 11:01 AM Sounds like you can rule out fuel pressure. The spark plug gap is .060. Just about every AC Delco plug I purchased had the gap right on but it never hurts to verify. Have you checked the throttle position sensor (TPS) out? At the electrical connector there will be about 5 volts from the PCM for reference voltage on one of the pins. Then on the output pin going back to the PCM you'll get around .4 volts at idle and 4.0 volts at WOT. In between the voltage reading should be progressive and linear. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
