Water in OIL what to do....
studious03
04-20-2006, 08:12 PM
was deciding to flush my radiator and when i checked my oil i noticed antifreeze/coolant on the stick(little orange bubbles). could this be the sign of a bad head gasket? Also noticed when i floor it(once in awhile) after its parked i notice antifreeze/coolant leaking.... anyone else have this problem....
silicon212
04-20-2006, 08:34 PM
Sounds like something bad ... head gasket, warped head (likely cause of a head gasket failure), bad intake manifold (water passageways corroded through allowing coolant into the lifter valley), cracked head and/or block ... whatever it is, you have a project on your hands and you better get it quickly - the coolant will damage the bearings.
