99 regal - changing front signal
dknapton
04-18-2006, 11:25 AM
Noticing that the front signal needing to be replaced, didn't see an easy way to remove and insert the new bulb. Is there a trick to this, or do I need a special tool to get at it from the back?
BNaylor
04-18-2006, 11:50 AM
No trick. To change lamps you need to remove the complete headlamp assembly or remove enough to pull forward. There are two L-shaped pull retainers on the back. Grab a hold of one and pull up. Remember there are two. Once done the lamp can be accessed for replacement. The socket holder will twist to get lamp out.
dknapton
04-18-2006, 09:14 PM
Thanks for the great instructions. Thought I was going to have to go to the dealer.
