chevy S-10 HELP!
Google
Web AF
chrsk
07-15-2002, 08:05 PM
I have Chevy S-10 2.5, top end rattle. Anyone know what this could possibly be?
Low Mileage engine.
TerminalVelocity
07-15-2002, 09:22 PM
ever change your oil?
Plugs, wires, distrubutor cap/rotor?
How many miles we talkin about?
chrsk
07-15-2002, 10:18 PM
It has 34 thousand miles on it.
Yes the oil has been changed, its not a spark knock or a rod knock or wrist pin.
Rich
07-16-2002, 09:45 AM
Low Mileage engine.
Can you be a bit more specific? Saying you have "top end rattle" is very hard to diagnose.
chrsk
07-16-2002, 05:15 PM
It sounds like the rattle is in the valves or lifters.
It just "pecks" when it idles. Any ideas?
wingofchicken18
10-18-2004, 03:43 PM
you probably have a rodknock, have you taken it in and had it checked out? And did you say a 2.2L? invest in s 4.3
Mikado14
10-18-2004, 08:56 PM
Just finished replacing an engine in one today. It had a horrible knock from the top end at higher RPM's over 2,000. At idle, it was smooth. The problem turned out to be a bad lifter on #4 intake. With the valve cover off, you could see the valve float and the rocker clearance would get as high as .125".
The customer opted to get a junkyard engine instead of repair and guess what? This one knocks also, but not as bad.
Fireplug
10-19-2004, 09:53 PM
Pull the valve cover off and check the rocker arm and is if any are loose or cracked also check the push rods. The 2.5 had a problem of putting push rods through the rocker arms. They would run good just make a hell of a racket up top.
Fireplug
Google
Web AF
