87 crx si fuel pump wiring question
Johnny Rotten
04-16-2006, 02:15 PM
My 87 crx has no power to the fuel pump.
It stalled shortly after an engine overhaul and will not start.
I replaced the main relay, the ecu, and the fuel pump.
Is there an inline fuse somewhere?
Can somebody tell me the routing of the wires?
What else could be the problem?
I have power to everything else.
Chilton's manual was no help.
lxndr
04-29-2006, 02:39 PM
I'd check the under dash fuses, main fuse box on inner fender, and I'd check for an electrical short to the fuel pump. If everything else has been replaced and working properly, it's gotta be an electrical issue.
Sometimes new parts don't work correctly, double check the fuel pump and main relay.
Also, Chilton's suck, Haynes is slightly better, or search the manuals section of www.redpepperracing.com for a printable version of the Civic factory service manual.
