Electrical Problem
KevinG
04-16-2006, 10:35 AM
Alright so when my car is on, everything pulses. What I mean by pulse is that every single light gets bright then dim then bright then dim really really quickly. Also, the battery gauge on my dash goes up and down very quickly. It probably only moves about 1/8 of the whole gauge.
Does anyone know what this is? If you need to I can get a video of the gauge and the lights tonight. I just got a new alternator like 6 months ago so I don't think that's it...
Thanks!!
92zcamaroperson
04-16-2006, 10:54 AM
is the flickering in time with the engine speed? could be a short or ground issue.
kahjdh
04-16-2006, 10:57 AM
Sounds like your alternator is going again, either that or a bad ground some where.
92zcamaroperson
04-16-2006, 10:59 AM
yeah engine vibration shaking a connection is what im refering to.
wrightz28
04-17-2006, 08:54 AM
Check the tensioner out, they're pretty low to the ground and I've replaced my neighbors a couple of times because they'll pick up slush and alot of water and make the spring weak.
