1997 Lumi 3.1 A/C probs....
Google
Web AF
Myxlplyxxx
04-15-2006, 10:06 PM
I put this A/C compressor in about 3 wks ago(old compressor pulley froze) it was used but was tested and does have a 1 yr warranty... anyway... The Pulley moves freely and the clutch does also...well I went to charge it today...I tested it and the pressure gauge read in the green(low)...so I tryed adding a little refrig.(yes on the Correct Line the connector is idiot proof) and it shot up to the warning(hi) mark on the test gauge... and the clutch never engaged... I checked the connector and its plugged in correctly to the compressor and I know about the relay(Ill test it tomorrow for continuity) by the coolant overflow and I cked all other fuses for it... it almost seems as if I cant get any refrig onboard:screwy: .... any Ideas would be a HUGE help... As Usual Thnx In advance...
MYX
richtazz
04-17-2006, 05:13 PM
the orifice filter in the return line to the condenser (high presusre side) is probably plugged with debris from when the compressor let go. It's a $3 part, and changing it will probably fix your issue.
Myxlplyxxx
04-17-2006, 10:26 PM
Thnx Richtazz... I kinda figured that but I need a honkin' big pair-o-wrenches to get the fittings loose.... any Clue what size they are by chance??? Biggest I got is a 19mm and 7/8 and not even close...1-1/4???...thnx man You've been alot of help!!!:)
MYX
richtazz
04-18-2006, 12:23 PM
I think it takes a left handed metric crescent wrench, but I'm not certain, :cwm27: Actually, I looked in the GM computer, and it doesn't give the fitting sizes, and the line is dealer only, so I can't just do a physical check for you. I tried.
Google
Web AF
