Flat spot on tire????seids 04-14-2006, 06:30 PM I Noticed one day while leaving the garage what seemed to be a flat spot on my front tire. Tire shop said it is probably a tie rod or ball joint? My tire also has excessive wear on the outside. Any ideas???? GTP Dad 04-14-2006, 07:00 PM Welcome to AF!! The alignment shop should be able to tell you what is wrong and their diagnosis is probably correct,but I don't think it is the tie rods, although the struts could be bad causing a lot of the problem with the tires. Have them check everything and don't let them replace anything without your permission. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
