turn signals don't work
Google
Web AF
grandmad
04-11-2006, 10:09 PM
Hey guys, I changed heater cores in my sons 94 Grand Am. Took the console out and the whole works. Everything seems fine with that now, but now the drivers side turn signal don't work. I replaced the bulbs. That was the easest thing. Still don't work. Could we have unhooked something? I can't even find the flasher. I am growing to hate this car more and more. Can you guys give me some advice? My 1970 Nova used to be so easy to work on.
snowtroll669
04-12-2006, 02:20 AM
ok do you have break lights and head lights and flashers to find the flasher cube you have to remove the consol under the staring wheel then remove the alumanim shield under that just left of the colum and just right of the emergancy break put your hand up in to the dash right behind the fuse box you will find the flasher cube its way up in there good luck
gmack221
04-12-2006, 09:25 AM
on my 95 the flasher was between the steering column & fuse box, under the dash, open the little door down there, I assume mine should have been clipped to the dash somewhere, but wasn't, it just fell out the door when I opened it. My car has 2 flashers, one for the 4-ways & one for the turn signals, if your right turn signals are working most likely its not the flasher.
The reason snowtroll669 asked if your brake lights work is because they run a power wire thru the turn signal switch on the steering column, if you have only the center brake light, or no brake lights then its probably a bad turn signal switch (pretty easy to get to on the new columns).
Google
Web AF
