Leaky Manifold gasketslimfatboy 04-11-2006, 10:13 AM I've got a little coolant coming out around the passenger side of the manifold and a puddle above the front furthest left cylinder behind the valve cover. My intentions are to change this when I get up to NY this weekend so I want to get the parts on order now, as AZ has most of the parts as special order. Does anybody have pertinant GM (or other) parts and PN's or related that should be replaced? I'm looking at zzp now and have (based on previously read thrds): -injector o-rings -oem L67 SC gasket -aluminum manifold gasket 99 gtp stock, with plans of modding in the future. Thanks, Ted richtazz 04-11-2006, 11:04 AM injector o-rings= AC delco 217-454 (gm12537425) $31.14 (dealer $62.26) s/c mount gasket= oem GM#24503911 (dealer only $9.95) **************Fel Pro # MS95744 $8.03 lower intake gasket = oem GM#89017825 (dealer only $57.39) ****************Fel-Pro # MS95977-1 $50.22 slimfatboy 04-11-2006, 11:12 AM Thanks, it's greatly appreciated. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
