Fobs
Google
Web AF
rockyneil
04-10-2006, 06:37 PM
How do I program a key FOB for a 2002 Corvette?
gmtech79
04-10-2006, 08:05 PM
Turn the ignition to ON.
Turn the radio to OFF.
Press the RESET button on the driver information center in order to clear any IPC warning messages.
Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
Press and hold the RESET button for 3 seconds.
Press the OPTIONS button until FOB TRAINING message is displayed.
Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1ST FOB will be displayed.
Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
rockyneil
04-18-2006, 06:24 PM
I received the info. on programming key FOB's for a 2002 Corvette. I have yet to get the remotes but have a copy of the steps. I am unsure where the reset is on the radio. I just want to get the info. straight in case I get the FOB's on the weekend. I would appreciate it if you could help "again". Thanks.
johnburrows
04-19-2006, 01:44 PM
neil, i stumbled across this forum while looking to reprogram my 98 corvette remote control. i did the procedure given above and it worked like a charm.
i think you are confused about the reset button though, it is not on the radio, but rather it is located with the driver information buttons to the right of the instrument panel. the other buttons there are something like "fuel" "gagues" "metric/english" "trip" or something like that. you know the ones. good luck.
Google
Web AF
