Rough idol and engine missing
Google
Web AF
joehfd
04-09-2006, 02:51 PM
On my 95 Blazer the engine is idoling rough its also missing its a 4.3 motor and it has been tuned up, also the fuel regulator has been replaced. Could it be an o2 scenser?
joe
cleanshavenrsx
04-09-2006, 04:00 PM
is there white smoke when you start it then goes away? mine does the exact thing. i replace my cpi, oil lines,wires,cap,rotor,plugsdid a motor and rad flush and still the same... i think its a lower intake gasket
Jon Teeter
04-09-2006, 05:55 PM
Try cleaning the EGR valve.Take it off and spray inside real good with PB blaster or brake cleaner
joehfd
04-09-2006, 06:40 PM
well the egr is new, I ran into a friend and he scaned it and the air temp circut came up soo i'm gonna replace the scencer an see wut that does
joehfd
04-10-2006, 09:04 AM
Well I found out the reason for the air sencer prob the wire was off the only other code coming up is for a misfire on cyl 3. anyone no wut would cause that? I also found some corosion on the coil wire by the coil side could that be part of the problem?
Joe
cleanshavenrsx
04-10-2006, 04:21 PM
make sure that wire wasnt melted by the header it happens all the time..
Google
Web AF
