00 grand am will stall at highway speeds
Google
Web AF
allanrigaud
04-08-2006, 04:20 PM
I have a 2000 grand am, every time im on the highway , around 70 or 80 mph the car will stall... so i have to pull out the road and wait like 5 minutes to turn it on again , and then i have to take avenues to get home..
I already change the fuel filter , but it seems that is not the problem. Its weird, because if i drive around avenues the car will run just nice, but on the highway will stall.. what i could be??
maxwedge
04-08-2006, 05:55 PM
Only way to find this to check for spark and injector pulse as the first step in the diagnostics, might see if it starts with starter fluid also.
DB90483
04-25-2006, 10:07 AM
Did you get the problem diagnosed? I'm having the exact same issue with a 2000 SE with the 4 cyl engine. 20 miles or so at 70mph and the engine just cuts out. Wait 5 minutes and it starts back up fine. Kind of dangerous when your in alot of traffic or construction zones with no place to pull over...
gravis2000
04-26-2006, 08:00 PM
Sounds like the computer is killing the engine.
ajtkimmel
05-21-2006, 01:11 AM
Just cruising through the GA forum and came across this one. I have a 1997 Blazer that was doing this very same thing and I finally chased the problem down to a junk ignition switch in the steering column. Whether or not it is the same problem or not. I know it is not the same column that is in the GA's but who knows.
DB90483
05-22-2006, 09:26 AM
Problem resolved for me - Fuel Filter.
$15.00 at N@pa and 15 minutes to change (even without the special tool)
I never would have thought a fuel filter could intermittently cause the car to quit.
xeroinfinity
05-22-2006, 01:21 PM
sometimes a faulty crankshaft position sensor will kill the engine, after it gets hot. :dunno:
Google
Web AF
