2000 Rodeohighjumper25 04-05-2006, 12:09 PM I have had this problem for 2 years and no one can seem to fix it. I have oil leaking into my number 1 and 3 sparkplugs. The valve cover gaskets have been changed three times and the problem is still there. Can anyone help me with this. I have to clean or change those two sparkplugs about every two days for it to run right. It is a 2000 Rodeo LSE V6 billindelicato 04-05-2006, 12:30 PM the problem isnt just the valve cover gasket its gaskets in the tubes that are causing your problem rodeo4me 04-05-2006, 01:00 PM I have also noticed oil on 1 first plug. How to fix it? highjumper25 04-05-2006, 01:13 PM the valve cover gasket has been changed along with the round ones at the top and i bought new boots (rubber things that run down the well) for those two sparkplugs. What gaskets in the tubes are you talking about. Thanks amigo-2k 04-05-2006, 01:40 PM When is the last time you changed out your PCV? highjumper25 04-05-2006, 01:43 PM I just changed it yesterday. It is running fine right now but I also cleaned the spark plugs too. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
