Lumina 1998 Relay where i can find it???
Google
Web AF
McLin
04-04-2006, 02:50 PM
Hi,
im looking for the turn signal relay, but i dont fin it...
I have just did found the harzad-warning signal flasher relay...
When i press the turn signal lever nothing hapened and i want change the relay, thx for answer...
richtazz
04-04-2006, 05:28 PM
the turn signal flasher is located under the dash between the steering column and radio(it's difficult to access). The turn signal/multifunction switch is a very common problem with these cars, and is most likely your issue.
McLin
04-05-2006, 12:58 AM
My car war skidded, an now the turn signal dont work, just the harzad-warning signal in front, but not in the back of the car...
But no cable was broke...
McLin
04-05-2006, 02:42 PM
Hi,
two way...
First im stupid or i cant see...
I didnt find the flasher, the one i found was behind the footbrake pedal, and thats for warning signal...
Can you help again?
richtazz
04-05-2006, 05:05 PM
The other is higher up under the dash, between the steering column and the radio/heater controls. By skidded, do you mean the car was in an accident? IF you have a bulb that doesn't light, is missing, broken or burnt out, the side it's on will not flash (thermal type flasher) or will flash very rapidly (electronic flasher). It's a built in safety feature to let you know a bulb is out.
McLin
04-05-2006, 06:23 PM
Hi,
the problem is, the normal light work fine, the warning light work just in front, but not in back, and the turn signal make nothing...
Nothing inside or outside, and the bulbs i have checked...
Must i pluged out the Radio to see the flasher?
McLin
04-06-2006, 11:41 AM
Whats about this???
http://img64.imageshack.us/img64/7506/turnsignal2zu.gif
McLin
04-06-2006, 01:23 PM
Is that normal if I the warning flashing arrangement switches on, and it flashes behind and the front if I switch the indicator counter to the left or on the right?
McLin
04-08-2006, 04:11 AM
I didnt find this f**king flasher...
Have anybody an pic of these pls???
richtazz
04-08-2006, 07:12 AM
I need to claify what you are saying the car is doing. From what I gather, you're saying:
1. When turned on, the hazard lights flash in the front, but not in the rear?
2. The turn signals don't flash at all, on either side front or rear?
3. No wires appear broken, cut or corroded, and all the bulbs seem OK and no bulbs are missing?
Please answer these questions so I'm clear, or clarify which question I have wrong. It will help in assisting you.
Also, do all your running lights work front and rear when the headlights are turned on?
McLin
04-08-2006, 07:41 AM
Yes thats is...
But the hazards lights flash at rear, when i make turn signal right or left...
richtazz
04-08-2006, 07:59 AM
Ok, that sounds like a ground back feed issue. The rear lamps are working when the turn signal is turned on because power is backfeeding through the turn signal switch and finding a ground.
To review a bit. The turn signals will not flash if one or more bulbs are inoperative. This is a safety feature built in to let you know that a bulb is out.
The hazard switch is wired to allow all good lamps to flash regardless of whether one or more is out.
One other question, do your brake lights work in the rear?
The reason I'm asking all these questions is that I don't believe the flasher is your problem. All power to the rear lighting is routed through the turn signal switch, and your symptoms are classic of a bad turn signal/multifunction switch (a very common problem on these cars).
McLin
04-08-2006, 09:32 AM
Hi,
yes the rear brake light are working all three...
Ok when the problem is by ground which one i must checking?
McLin
04-08-2006, 09:41 AM
i have found this...
http://corvette.web1.kostenloses-webhosting.de/98Lumina_turnsignal.pdf
richtazz
04-08-2006, 09:58 AM
I double checked the GM computer, and it only lists one flasher for both the hazard and turn signals on your year Lumina, so your problem has to be in the turn signal/multifunction switch. IF it were the flasher, neither would work.
McLin
04-08-2006, 04:08 PM
Hi,
thx for Help, it is the switch...
Where can i order this?
And how much cost it? I will do it self...
McLin
04-09-2006, 04:43 PM
It was the Harzad Warning Switch that was hanging, but now all works fine...:banghead:
Thx@all...
Google
Web AF
