Air Conditioning Squeel
Google
Web AF
kenc195
04-03-2006, 05:03 PM
1997 Passport, 165,000 miles. Recently when starting cold I have had a 2-3 second squeel from under the hood. I inspected the belts which were worn and replaced them all. Problem continued
Started getting hot here in Phoenix and turned on the AC which prompted a 2-3 second squeel. Each time the compressor cycles I have a squeel.
Should I suspect the AC clutch? and how hard is DIY replacement?
Canucklehead
04-03-2006, 06:42 PM
Should I suspect the AC clutch? and how hard is DIY replacement?I would suspect the alternator belt is loose.
2eyefishclaw
04-03-2006, 07:41 PM
usually alt belt it can make one hell of a noise. needs to be tight
kenc195
04-04-2006, 05:57 PM
Just felt the belt and it probably could be tighter. Will adjust it and let you know
kenc195
04-10-2006, 12:22 PM
Problem fixed:) Tightned the alternator and AC belts and everything just fine. Thanks guys
Google
Web AF
