Window Problem
vik
07-11-2002, 12:08 AM
for some reason my finds go up slow. this has been happening for a while. my battery is new. and i cant find any other reason why it would do dat. thanx
strodda
07-11-2002, 01:47 AM
i have no idea what a "finds" is, but im assuming you meant something about your windows(from the topic). anyways, its probably the motor inside the door. its just a random problem. my friends got a 97, and his driver side completely stopped working. my car is 6 years older, and they work great. as in most cases, best bet would be ebay. ive actually seen window motors on sale before.
HONDA_99
07-11-2002, 07:04 AM
your signature says J30A1 (98/02 V6 engine), but your profile says 96 Accord.
what Accord do you have?
5gen Accord known for bad driver side window. seal in tracks get swollen, over years, which slows window on way up, and some times it can even stop.
vik
07-12-2002, 12:28 AM
i have a 96 v6. i was tryin to figure out wat kind of engine i have. so i checked this site out and thats wat it said. if u really know wat tha engine is, please let me know cuz i dont wanna look like a dumb fuc.
HONDA_99
07-12-2002, 06:31 AM
5gen Accord V6 (95-97) has C27 engine, its same engine as 1gen Acura Legend has.
diesel_uk
07-12-2002, 10:20 AM
Hiya mate back to the reason of your post.
honda's suffer from whats dealers robbing syndrome.
If you look at the rubber seals on your window they need lubrication on a regular baisis ( i lube mine evrytime i give my car a good washand polish) what i use is silicon lube i'm sure you guys will have the same. When you wash your car use it evrytime as "Prevention is better than the cure"you spray it on the rubber seals on the window winding mech.Also may i add with age it also needs lubing on a regular basis. i hope it helps
