Grinding & Loss of brakesdhodson2004 03-28-2006, 10:45 PM 1999 Chevy Silverado 1500 4X4 5.3L Ext. Cab Today while in Walmart's parking lot, I slowed down and cut the wheels to the right to park. Then I heard a bizarre grinding noise and the brakes would not work. When I left the lot, they worked fine. I think it is the ABS sensor needing cleaning. How would I go about doing this on a 4X4? Thanks for the help. pkbfree 03-29-2006, 10:13 AM Interesting - If you live someplace salty, it may be the sensors. Chevy just had a recall on model year 2000 for ABS sensors. See if you have a freeby coming. MT-2500 03-29-2006, 10:30 AM Any ABS brake lights on. A good scan with a ABS capable scanner may point to the root problem. Could be a sensor or could other stuff to. The old scanner will point you in the right direction. if you can get any codes post back codes. And like said a recall may be the fix. Have your dealer run your vin no for recalls and TSB's on it. MT dhodson2004 03-29-2006, 11:15 AM Maine winters are usually very salty. There are no lights on, but my brother does have a scan tool. I'll see if he'll do it Saturday. I'll check on the recalls and see if I'm covered or not. Thanks for the replies! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
