94 fuel problem
88posnismo
03-27-2006, 06:55 PM
I have a 94 cavy with 127,000 miles and i am have a problem with the fuel system. Fuel pump was not working so i replaced it with a new one and it still does not send fuel. Relay and the fuse are good. I'm thinking there is a bad wire or ground somewhere. Does anyone have any ideas or have run into this problem before. Thanks for your input, Kyle :crying: :banghead:
94VL
03-28-2006, 12:48 PM
Sounds like bad wiring for sure.You probably should try force feeding the pump first though.There is a hanging connector at the drivers side firewall,feed it 12V and see if the pump runs.If it does,the wiring is ok.If it doesnt run,its bad wiring or a bad pump.
88posnismo
03-28-2006, 03:12 PM
thanks,unfortunatly i will have to find the wire and replace it. I did force feed the pump it still did not work.
