Our Community is 662,000 Strong. Join Us.
gas gauge stuck at 1/2
tonejones
03-27-2006, 01:38 PM
My gas gauge on my 1997 Escort is stuck at 1/2 no matter how much gas is in it? Is it the sender, and where can I find it?
KimMG
03-27-2006, 11:34 PM
The sending unit is in the gas tank.
Try autozone.com for a free repair guide for testing procedures.
Davescort97
03-28-2006, 06:21 PM
To check the sending unit put the test leads of an ohmmeter on the sending unit terminals and check the resistance. Use the 200-ohm scale on the ohmeter. With the float in the lowered position (Fuel tank empty) resistance should be about 22 ohms. With the float raised (Fuel tank full) the resistance should be about 145 ohms. The resistance should change smoothly as the float is moved. If the readings are incorrect replace the sending unit.
There's a 10 amp meter fuse in the passenger fuse block. It controls the temperature gauge, too, so if the temp gauge works the fuse is probably all rightl.
