Installed a new muffler
Google
Web AF
Cloud Strife
03-20-2006, 04:05 PM
Well I bit the bullet. I have pondered numerous things to put on my 99' Blazer 4x4 LS. There were catbacks, mufflers, or leave it stock. I just chose replacing the muffler.
I hunted around a Midas for a Ravin Z55. But it was 3" in and 3" out. And they wanted about 350 bucks for everything. I about crapped myself this morning.
I almost pulled the trigger on a Gibson catback or a Dynomax Super Turbo kit.
Instead I opted for a Flo-pro Soundpro. I think that is it. I left stock piping in. The muffler itself was 43 bucks and installation was like 35 bucks. In & out of the shop in 30 minutes.
The result is much nicer over stock. There is a deeper grumble when you start it up. When idling at a red light you can hear the low grumble in the cabin. It gets a louder when you mash the gas. At highway speeds it is barely noticable. I wasn't interested in something that will deafen me but for the smooth sound.
Now for the performance. I can feel that my Blazer is enjoying the new muffler. Acceleration is significantly smoother around the 2500 to 3500 RPM range. Before I could feel it bogging down a little. Not anymore. I idle about 100 rpm lower. I have good pickup when I give it that gas even at 55mph. I was able to squeel the tires at a red light shortly after the installation upon take off.
Now I am going to have to look in the cold air intakes. Ebay seems like my best choice hear. Chromeintakes is a vendor that ppl are recommending quite well. I talked to the guy who was doing the muffler there and he said the K&N FIPK on his 03' Silverado resulted in about 4 mpg when he stuck on one.
But for right now I have a K&N drop in filter. I am going to remove the stock box and try how it will feel with a cold air simulation. But first I will have to reset the ECM here shortly.
I know some of you want sound clips. I will have to try setting my laptop up nearby for a recording. I will have to see how the weather ends up here this evening first.
TheBrettster
03-20-2006, 06:03 PM
sweet stuff. i have an 01 blazer and i'm searching for that ravin. does it sound like a v8?
BlazerLT
03-20-2006, 07:20 PM
Holy hell they were trying to rape you for the z55.
Cloud Strife
03-20-2006, 10:32 PM
Yeha and I told them to shove that quote up his ass once he told me it.
I was not able to get a sound clip this evening as I went to a church mens meeting. I will have it for tomorrow. I have absolutely nothing to do.
This muffler makes it sound like a V8 under the hood. But it doesn't do it in a loud annoying way. You will have listen to the clips to see.
BlazerLT
03-21-2006, 08:26 AM
True, make sure you post them up.
tuellz
03-21-2006, 11:11 AM
SNIP (Do folks in this forum "snip"? INWN?)
SNIP
As a newbie who has spent hours and hours pouring over this forum, I'm still not convinced that "oiled" filters (K&N-type) are the way to go. The replacement cost of that MAF sensor bothers me a lot. Yes, if you are lucky, you can successfully clean the MAF (OOPS! That's gonna be expensive.) but cleaning would likely come after a period of crappy performance/lowering MPG/money down the drain. Is there no middle ground here? Is there no filter better than stock that will not (potentially) do hundreds of $$ damage?
Phillip
BlazerLT
03-21-2006, 01:07 PM
K&N is perfectly safe if you don't go overboard on the oil.
1000s of MAF vehicles have them with no issue.
Google
Web AF
