hole by tanny
Google
Web AF
mhowe1182
03-20-2006, 03:52 PM
there this hole by my tranny and i want to know if its sopose to be there.
MT-2500
03-20-2006, 05:18 PM
Has it got a year or engine or what trans or mileage?
They have a lot of holes in them.
Like what kind of a hole or is any fluid running out of it?
Where is the hole? How big is it?
WHAT IS IT DOING OR NOT DOING?
And like my mama told me do not go around sticking you finger in strange holes to check them out
MT
SComp23
03-20-2006, 05:49 PM
He might be talking about the wephole in the bellhousing on the 4L60E tranny..... If this is the case, yes, it is supposed to be there.
mhowe1182
03-20-2006, 07:01 PM
u r right but it leaks alot and my tranny take sometime to shift from third to fourth.:smokin:
mhowe1182
03-20-2006, 07:02 PM
u r right but it leaks alot and my tranny take sometime to shift from third to fourth.:smokin: :
SComp23
03-20-2006, 07:12 PM
Is it leaking oil or tranny fluid?
BlazerLT
03-20-2006, 07:16 PM
Is the tranny overfilled?
mhowe1182
03-24-2006, 10:42 AM
no i keep having to put more fluid in it leaves a puddle on the ground.:smokin:
SComp23
03-24-2006, 10:49 AM
So it is tranny fluid for sure, not oil?
MT-2500
03-24-2006, 11:25 AM
MT
We can not help you unless you help us. We need more info.:grinyes: :lol: :feedback:
Do hold back give us all you have got. We are not mind readers.
MT :feedback:
Bolognabob
03-24-2006, 12:08 PM
front pump seal??????
BlazerLT
03-24-2006, 01:40 PM
Are you checking the tranny fluid level when the engine is hot and idling in park?
mhowe1182
03-25-2006, 12:10 PM
yeah thats how you check it anyways. and what front pump seal?:smokin:
Bolognabob
03-25-2006, 01:53 PM
the shaft seal on the front pump...... behind the torque converter.....
MT-2500
03-25-2006, 03:14 PM
MT
Well good grief.:banghead:
Give us some info so we can help or quit wasting our time.:grinyes: :lol:
We can not help unless you help us?:nono:
MT
mhowe1182
03-26-2006, 11:32 AM
what about the front seal?and the year is 85 k10 blazer and its got a 305,th400 tranny. not sure if the miles are correct but it says like 47000.
:smokin:
mhowe1182
03-26-2006, 11:36 AM
im sure that its tranny fluid because of the smell.:smokin:
MT-2500
03-26-2006, 12:55 PM
:smokin:
Ok now we are going places or getting some where on it.:grinyes: :lol:
But you are going to have to crawl under there and have a look at it.
The 400 transmission does not have any holes in it but the splash cover on the converter that does have.
So you will need to remove the splash cover and have a look in there.
With cover off you will be able to see the front seal.
If it is a leak when the engine is running it will be a pressure leak like front seal or trans cooler line.
If it leaks sitting it could be a pan gasket or dip stick tube or front pump gasket.
Clean off the old oil and remove that splash cover and have a look and you will see what is leaking.
Post back what you see or find out.
MT
muddog321
03-27-2006, 11:40 AM
Those Turbo 400s could leak at the vac modulator, the trans lines to the radiator, dip stick tube o-ring, or the pan gasket. That 47000 is most probably 247000 on an 85 so lots of use - speedo had no hundred thousand place - had one.
BlazerLT
03-29-2006, 02:17 AM
You don't go by smell.
It could be brake fluid, or any type of fluid really.
mhowe1182
03-29-2006, 04:43 PM
i know what tranny fluid smells like and it smells like tranny fluid.
mhowe1182
03-29-2006, 04:44 PM
thanks MT-2500 i will give it a shot and get back.:smokin:
Google
Web AF
