Stock radio + sub/amp questioncynik6 03-19-2006, 10:24 PM I'm curious to know if an amp and sub could be added to the stock radio in a '00 Silverado. Is it true that the stock harness doesn't have everything it needs to hook them up? sportin83 03-19-2006, 11:22 PM I'm curious to know if an amp and sub could be added to the stock radio in a '00 Silverado. Is it true that the stock harness doesn't have everything it needs to hook them up? you will need a line output converter about 15-30 bucks from a audio shop. that converter will tap into the speaker wires and convert it into rca's. then you hook a remote wire to the acc wire on the radio and run your power to the battery and ground to the frame. easy as that. korndogg 03-19-2006, 11:52 PM what he said grego10r 03-20-2006, 02:31 AM i did run this setup and its sound good vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
