z34 5 speedluminaguyryan 03-19-2006, 09:13 PM dose any one no if i need the actuator that is on a braket on the trans. its on the driver side between the trans. and fire wall or if i can just get rid of it i think it has to do with the shifting jeffcoslacker 03-20-2006, 10:46 AM dose any one no if i need the aculater for the cluch systum or if i can just get rid of it I wish I had any idea what you said....:frown: richtazz 03-20-2006, 03:16 PM the clutch actuator, or slave cylinder in common terms, is not something you can't get rid of. It's what disengages the clutch disc when you push the clutch pedal so you can shift gears. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
