Bad noise Trans. case.eraseraj 03-15-2006, 08:48 PM when i was driving offroad the other day i wanted to try to put my jeep grand LTD. in 4x4 LO but there was this bad grind comming from the jeep when i put it in drive. i took it out of LO as soo as possible (1 sec.) could this have done alot of harm to my jeep. i mean it drives fine but should i get it checked out. Thanks dksob81 03-16-2006, 07:49 AM No it won't do any harm, this happens often, You prolly didn't have it all the way in 4LO or the TC Linkage might need adjustment. Did you come to a complete stop, Put the tranny in NEUTRAL then pull back on the TC lever to put it in 4LO without pausing in any other gears? eraseraj 03-16-2006, 01:29 PM yes the jeep was in neutral and stoped before i put 4 LO in but it still made the noise does anyone have any tricks or tips to 4LO??? Thankyou Andrew dksob81 03-16-2006, 05:16 PM ok then, your linkage for the transfer case will need to be adjusted. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
