Remote starterLiljay2003 03-14-2006, 05:30 PM Yeah i have a remote starter on my 2002 Grand Prix, and you they have a lil sensor in the key that the engine wont stay runnin without the key in the ignition and when i use remote start , it will start but i have to have the key in there to keep it started. and i was wondering if there is a sensor in the igntion that i can trick or something to make the computer think theres a key in there. maistro0 03-14-2006, 07:30 PM hope this helps you there is actually a bypass module you have to buy seperatly what is deose it sends a signal to youre stock security so it allow it to start without the key you can buy this module at any store that sells and installs alarms i had to do the same thing to my old truck because it had a stock security butt its very simple to intstall.good luck ponchonutty 03-14-2006, 07:54 PM You have the PK3 system. The easiest thing (if you have 2 working keys) is to go to the dealer and have them cut a new key and program it to your car yourself. Then go to local alarm shop or car parts place and buy the bypass where you place an extra key inside it. Liljay2003 03-14-2006, 09:01 PM all alright thanx, will it still go dead if the car goes in gear, b/cuz i just want it to stay crunk without the key, i dont want it to be able to drive without the key< well i guess it realy dont matter< b/cuz right now i'm leavin the key in there and if some broke into the car, i guess it will be long gone anyway. ponchonutty 03-14-2006, 09:28 PM The module with the key inside will be not seen anywhere. Plus the wheel and gear shift will be locked. Goto www.directed.com and go to the online store and find the 556u that's what you need. indyram 03-15-2006, 09:13 PM If you get the correct bypass module, for the pk3 system I think it is #2, you don't need to put an extra key in there. The module works on it's own without the key. Liljay2003 03-15-2006, 10:04 PM So its called PK3 system, do you know about how much it cost and how to install it. ponchonutty 03-16-2006, 07:49 AM Yes, the DEI part 556u is simple 2 wire hookup. The 555g is a little more involved and I don't like it. It doesn't always work correctly. This kit http://bypasskit.com/product.aspx?prodid=GMBP is what I would recomend instead. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
