programming a keyless remote
Google
Web AF
Sybock
07-04-2002, 08:37 PM
Does anyone know how to program a keyless remote for a 2000 Chev Venture? I tried 'hold power lock' , 'key on and off' routine....plus the BCM fuse pull method but for some reason nothing seems to work. Replacement remote I have is suppose to work with Venture/Montana's from '98 - 2002. Any info appreciated. Thanks
tradeweb
10-21-2002, 09:34 AM
This worked for me on my 2002 Chevy Venture. I got it from a post from a 1999 GMC post.
Important! Once the BCM enters program mode, all transmitters must be programmed at the same time. Any transmitters not learned at this time will be erased.
1) Remove the key from the ignition cylinder
2) Remove the BCM PRGRM fuse from the fuse panel
3) Close all the doors
4) Close the liftgate
5) Turn the ign lock cylinder to the ACC. position
6) Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second
7) Open and close any door
Achim will be heard when the system enters the BCM programming mode
IMPORTANT!
After 7 seconds a chime may be heard confirming successful synchronization. It is necessar to wait approximately 14 seconds for a second chime that will confirm successful programming.
8) Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds
9) Repeat the previous step on each additional transmitter to be programmed.
10) Remove the ignition key from the ignition cylinder
11) Install the BCM PRGRM fuse back into the fuse panel.
ttrigg
11-30-2002, 02:40 PM
I was told by a Chevrolet dealer place that they can not program the remote I purchased from them because the BCM is out. Can it be they did not know how to do it?
dabobcan
04-26-2003, 12:40 PM
I just tried these instructions on a 1998 Chevy Venture and it worked great. A lot of thanks goes out to these forums.:flash:
Karina
06-03-2003, 11:50 PM
I tried these instructions on my 1998 Venture LS and I would make the following revision. Step 7: Open and close passenger door. The original instructions indicate to open and close any door. I tried it first with the driver's door,but that did not work; the passenger's door did.
Thanks a lot! The instructions were very helpful!
jsstubby
12-06-2003, 04:40 PM
I have followed this procedure for my 98 Chevy Venture and I never get a successful programming chime. I don't think I am getting the timming right somehow because the chimes don't seem to match up with the procedure given above. What am I missing?
bryantj
02-01-2005, 08:01 PM
hello my great grand pa got a 00 venture and he wants it the lights to flash or horn to blow when he locks it and i did what the maual said and it wouldn't work but i didn't close all the doors would that matter oh its an ls with auto sliding door and i was wondering if u could configuer the door so u wouldn;t have to put it in park to open it ? plz if u have an answer to this email me chmsboy14@msn.com thx
ssibiga4
08-11-2007, 10:20 AM
I'm having trouble w/programming keyless remote for 2000 chevy venture lt model. I have tried the steps that are posted w/out success. Any other ideas out there to help resolve my problem.thanks SS
'97ventureowner
08-11-2007, 12:52 PM
This thread is over 5 years old with the last response over 2 1/2 years ago.Please start a new thread to ask your question and link to this thread rather than resurrecting such an old thread.
Closed.
Google
Web AF
