94 Blazer will not idle .
Sinkerman
03-13-2006, 05:11 PM
I have posted before . Stated I have high idle , Actual I have no idle . Have changed eveything you can think of.. from the Air control valve, pump, pressure control valve.. on, and on.... computer , prom,.... Need advice.. Thanks..!! . 350 V-8 injector. automatic.
MT-2500
03-14-2006, 06:12 PM
I asume you mean a real fast idle.
If it has TBI injection remove the throttle body and replace the base gasket.
MT
MT
Sinkerman
03-14-2006, 10:29 PM
checked the gasket . The only way the Blazer runs is if you keep your foot on the gas pedal. at about 1500. Anything below that and it dies. So I guess you can call that high idle.. but the problem is as soon as you remove your foot it dies. Keep your foot on the gas and it will run. Put it in gear and you have to step on the gas. Will not idle. ??? Its just crazy. can't figure this out. Thanks !
MT-2500
03-15-2006, 08:31 AM
Get a scanner on it and check IAC valve operation and circuit.
Markgc
03-15-2006, 05:27 PM
I went through this with my 350 V8 in my 89 Silverado. It wouldn't idle unless I kept it reved up. I changed the IAC valve and MAP sensor but it did no good. Are you getting a hard brake pedal with no vacuum assist?
In the end my problem was the EGR valve. A new valve and the trucks idles just perfectly now
Mark
Mark
MT-2500
03-15-2006, 06:01 PM
Mark
Good call there Markgc
I can not figure out why I did not think of that. :grinyes: :lol:
Mt
Mark
Mt
Markgc
03-15-2006, 06:08 PM
Thanks - I hope it fixes it for him.
Now if i can only get my Blazer going.
MT-2500
03-15-2006, 06:55 PM
10-4 on that.
And if you need help on yours just start a new post and post the problem and info someone will help you.
Good luck with it.
MT
10-4 on that.
Good luck with it.
MT
Markgc
03-15-2006, 07:02 PM
Yes I should have posted the link
http://www.automotiveforums.com/vbulletin/showthread.php?t=532970
Not sure how to proceed with this one now.
