alright more brake problems
DarkGP
03-12-2006, 08:26 PM
ok i have a 95 GP and it has abs but it hasnt been working for about a year, but thats ok cuz i dont really like abs but just recently i have noticed that when i am hard on the brakes the RR tends to lock up first the the LR then the front, i had the code checked and its the speed sensor in the RR, would that cause something like that to happen? this problem isnt to big of a deal cause its pretty awsome to hit the brakes around a corner and have the back end kick out but its not to safe and my brother will be getting the car soon so i want to fix this problem
JonJon68
03-13-2006, 06:26 AM
Replace the RR hub/speed senser
richtazz
03-13-2006, 08:28 AM
:iagree: Since the hubs are expensive, you can check the harness for corrosion, and test the sensor with an ohm meter.
DarkGP
03-15-2006, 06:36 PM
ok ya the speed sensor is alittle dirty so im gonna get the wiring and clean it out and plug the new one in, also why would it take this long its been over a yr for this to start happening
