where does my oil go?
carpenter_jai
03-12-2006, 02:59 AM
Ok, here's the situation. Several times now, I have noticed that when I change my oil, not enough is draining out. The crankase is topped up to the full line, but only two litres (do you use litres in the states?) come out. So I change my friends oil today, same engine, and there is way more oil coming out of hers, ie. the correct amount. My manual says that the capacity of the crankcase and filter is 3.3 litres.
What gives, is my oil turning to sludge and accumulating in my oil pan?
If I take off the oil pan, do I need to replace the gasket?
spy1309
03-12-2006, 06:43 AM
In the states we use quarts one quart=0.9l , you can take the oil pan out and check for sludge and clean the oil pan, one other reason is that the oil return holes from the head might be obstructed or with deposits on them so the oil takes a longer time to go down in the crankcase,for the oil pan you can use hi temperature silicone instead of the cork gasket.
gumby_ct
03-12-2006, 07:09 PM
Assuming you are measuring both cars before the oil change - I gotta ask - are the dipsticks the same length? Draining on a hill/slope? Tilted one way or the other? Using the same drain pan to compare? Doing something different?
carpenter_jai
03-13-2006, 02:01 AM
Yeah, I changed the oil in both cars at the same time. Same evrything except that her car is a 96, and mine is a 95. Drain pan was about half full from my car, and was only an inch from the top. I poured both back into differant one gallon containers for disposal. I filled mine a little over half full, and hers was almost to the top. These engines are both 1.o litres. Both were run before draining.
:confused:
Jai
geozukigti
03-13-2006, 04:22 PM
Your engine is probably burning it. Some metros that are driven a lot on the highway with an auto trans(constant high RPM's) are prone to the oil rings wearing out. What weight of oil do you use? Perhaps try using an engine flush in your car. Your oil rings could have siezed with carbon and funk on them. If you don't notice smoke, it could be passing oil through the exhaust valve seals. Try 10w30 oil if you aren't already. And keep an eye on the oil level.
gumby_ct
03-13-2006, 06:03 PM
Yeah...shame on Gumby for
Assuming you are measuring both cars before the oil change .
iheartguysinmetros
03-13-2006, 08:18 PM
If the crank case is topped to the full line, does it burn while he is draining it?:shakehead
JimboJ
03-13-2006, 08:49 PM
Nope only between filling and the next oil change silly....
Check it weekly and watch for it going down, could be leaks and could be burning.. According to GM rtv is enough to seal pan...
iheartguysinmetros
03-13-2006, 09:06 PM
I was being silly. He said it was full when he drained it. How could it have burned off if it was full?
carpenter_jai
03-14-2006, 01:05 AM
If you read further back, you would see that the oil was topped up to the full mark on the dipstick in both vehicles. Both metros have oil leaks, so we are both checking oil levels regularily. My car leaks oil at the head gasket. It may burn some as well, but it isn't showing in the exhaust. There are no signs of coolant being burned, in fact, I haven't had to add any for 3 years.
I can't use it. It gets down to -25c/-13f here regularly, so that stuff will cause me to seize up. I do use it in the summer though.
I have a 95 3 cyl manual. My driving habits are typically 95 percnet city.
My compresion is a little low, but I don't know if it is caused by the head gasket leak, or worn rings. Before the leak occured, I believe I was loosing a quart/litre between changes 5000 km/ 3100 miles.
Anyway, this is all pointless because we both start with the same amount in the crankcase, according to the dipsticks, but only 2 and a half quarts come out of mine.
:banghead:
Jai
iheartguysinmetros
03-14-2006, 03:55 AM
:banghead:
Jai
http://www.freshaircafe.com/m_bliss.gif
geozukigti
03-14-2006, 10:20 AM
Oops, I mis-read his original post :banghead: I thought he meant it was full when he first changed it :)
Your oil could be pretty thick if it's cold out. Did you let the car warm up for a few minutes before you drained the oil? Perhaps you should pull your oil pan and check it, you may have a bunch of sludge built up in the bottom of it.
carpenter_jai
03-15-2006, 01:54 AM
Like I said earlier in this thread, the oil was drained when the engine was hot. I also guessed that it may be sludge, and was looking for a second opinion. I know you're getting picked on lately, so I want you to know that I sk this with the best possible intentions. Geozuki, why do you reply to threads when you have only read half the information? I always try to write all the relevant info with my first question, so I don't have to write it later.
Jai
iheartguysinmetros
03-15-2006, 02:28 AM
Jai
http://www.freshaircafe.com/amen.gif
http://www.freshaircafe.com/bowdown.gif
geozukigti
03-15-2006, 08:53 AM
Jai
If you would have read my previous post completely, it explained that I mis-interpreted your post. Sorry for giving a suggestion. I'll remember to ignore your posts from now on.
WildCherryPepsi
03-15-2006, 04:36 PM
Becareful Jai I dont want what happened to me to happen to you. Today I opened up one of my email accounts to find the following email account signed in my name.
<begin>
Display images below - Always display images from slackerinformation@yahoo.com
geozukigti
Note: forwarded message attached.
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com (http://mail.yahoo.com/)
---------- Forwarded message ----------
To: slackerinformation@yahoo.com
Date: Tue, 14 Mar 2006 12:00:41 -0800 (PST)
Subject: Welcome to Yahoo!
:22yikes: How does that happen?
geozukigti
03-15-2006, 09:03 PM
<begin>
geozukigti
Do You Yahoo!?
:rofl: :rofl: :rofl:
Cause ya know, it's possible for me to sign into someone else's Yahoo email using MY automotiveforums sign-in :screwy: Always trying to cause trouble I see :nono: :shakehead
JimboJ
03-15-2006, 10:44 PM
Actually my skateboard hits low 6's but only when towed behind my warp engine equipped metro which needs dilithium :grinyes: :grinyes: ..
carpenter_jai
03-16-2006, 03:25 AM
Look, I have no desire to enter into a pissing match, if that's how it looks, then you win! I was just trying to make a point. And this is it. Zuke, you're posts say;
Oops, I mis-read his original post I thought he meant it was full when he first changed it
This information is in my very first post in this thread. I'll copy it here for you.
[QUOTE]Ok, here's the situation. Several times now, I have noticed that when I change my oil, not enough is draining out. The crankase is topped up to the full line, but only two litres (do you use litres in the states?) come out. So I change my friends oil today, same engine, and there is way more oil coming out of hers, ie. the correct amount. My manual says that the capacity of the crankcase and filter is 3.3 litres.
And my second post:
I appreciate everyones imput here, except iheartguysinmetros, and wildcherrypepsi. It's hard to find good advice for free, so if it sounds like I'm critisizing, then consider this thought. My remark to read the whole post may have been to save you the time of asking questions already answered, thereby streamlining the process for all involved. If you still think I'm a jerk, go ahead, I don't care. I had no ill intentions, and still don't. I believe it was you who said something like, "it's just an automotive forum.:smokin:" My thoughts exactly. :sunglasse
Jai
Mushijobah
03-16-2006, 04:42 PM
try using synthetic oil and drain while the engine is still warm. Synthetic oil acts as an engine cleaner because it does not gung up as non-synthetic does, melting away gunk. Take the cap off too when draining.
unbe
03-16-2006, 05:37 PM
They make stuff to flush your crankcase you might want to consider using it.I have no personal experience with it has anyone else??
