Radio fuseWeedo 03-10-2006, 05:15 PM I have a 1996 Firebird. I'm looking for the radio fuse but there doesn't seem to be one unless its sharing with something else and isn't specifically listed. Does anyone know which fuse it might be? I'm trying to program a new rke and it's not working. It calls for removing the radio fuse. Thanks CreepingDeath94 03-10-2006, 07:11 PM Usually the radio fuse shares with cigarette lighter. It should be labeled radio. This may be a dumb question, but you are looking at the fuses on the drivers side of the dashboard right and not under the hood? It is a 10 amp red fuse normally... Weedo 03-13-2006, 05:47 AM I was looking under the hood. So I guess I'll check under the dash then. Thanks. CreepingDeath94 03-13-2006, 06:12 PM It happens. By the way, I wasn't trying to be insulting or anything, its just if I would have said look under the dash and thats where you were already looking, you may have gotten upset :-p. Anyway, good luck. Weedo 03-16-2006, 07:44 PM No insult taken at all. I had no idea there were more fuses in the dash. I did find them and I did get the rke programmed, unfortunately it doesn't silence the alarm (which it sets off when I try to use it) so I can't use it anyway. :banghead: It's always something. Thanks for the help. It happens. By the way, I wasn't trying to be insulting or anything, its just if I would have said look under the dash and thats where you were already looking, you may have gotten upset :-p. Anyway, good luck. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
