1997 pgp gtp 3.8 super abs lite
Google
Web AF
jeremy06
03-10-2006, 05:11 AM
any ideas to what would cause the abs lite to come or or known problems with the braking system?
richtazz
03-10-2006, 07:01 AM
the most common problem to cause an abs light to come on is a bad wheel speed sensor (part of the hub bearing).
BNaylor
03-10-2006, 08:28 AM
Typically, the best way to diagnose the ABS braking system is getting it scanned with a scanner capable of detecting GM CHASSIS/ABS DTC error codes. Like mentioned above it could be any hub/bearing/wheel sensor or problem with the ABS motor/modulator, EBCTM control module or associated wiring.
1typhoon
03-10-2006, 05:42 PM
Most likely a wheel sensor. Check that all 4 are plugged in properly. It is an easy DIY to check the wheel sensors. Using an ohm meter check the resistance of each wheel sensor. They should measure around 1k ohms, give or take.
Google
Web AF
