Front sway links and bushings?
Google
Web AF
FRANKENCAMRY
03-09-2006, 09:46 PM
Just replaced the front struts and mounts on my 93 LE. Still getting a little front end rattle over some surfaces. Thinking it might be the front sway bar links and/or the sway bar bushings. Didn't really look at them while I was in there. How do you check these? What is the symptom when they're shot?
Toysrme
03-10-2006, 06:20 PM
Taken them off & check their rubber bushing. Check the sway bar bushings also. Use lock-tite when re-installing the sway bar end links. They are pretty bad to vibrate off.
For the bushings, you need to grease them up very well, or they'll start squeaking.
Google
Web AF
