Our Community is 662,000 Strong. Join Us.
clicking noise
scorpio1225
03-09-2006, 06:52 PM
I have an 95 escort that has a loud clicking noise that is coming from the passenger side of car. It sounds like it is coming from the front passenger wheel. I was wondering if this is possibly the wheel bearings or something else.
Davescort97
03-10-2006, 08:45 PM
It could be a bearing. If the faster you go the ticking gets faster it is related to wheel speed. If it's something in the engine it will click faster as you rev the engine up while standing still. What's it do under these two conditions?
scorpio1225
03-11-2006, 05:09 AM
I only hear the clicking noise when it is moving. When I rev the engine it does not make the noise.
C. Cleve
03-11-2006, 05:26 AM
Hi, RE, your clicking noise, let's try to pin it down further, does it go away when you apply the brake? If so it is probably the slide pins worn on the brake calipers, causeing the pads to rattle,, Let me know....Clay..
scorpio1225
03-13-2006, 04:53 PM
The clicking noise is still heard when applying the brakes.
Black2000Ranger
03-13-2006, 05:31 PM
Sounds to me that it is the CV joint. Does it make the noise louder if you turn sharply to the left or the right?
-Scott
scorpio1225
03-15-2006, 07:06 PM
It does make alot of popping noises when I turn to the left or right
C. Cleve
03-16-2006, 05:15 AM
Hi, You have diagnosed your problem, It's a cv joint, now all you have to do is find out which one....By the way it's cheaper and less hassle if you just replace the axle shaft assy.....Autozone about $60. Good Luck...Clay..
