1987 Nissan Stanza - Starting/Dyingmo6697 03-09-2006, 02:55 PM 1987 Nissan Stanza fuel pressure good, plugs done, fuel filter changed etc. Car will drive for a few minutes then die. Let it sit for awhile, then it might start. Any suggestions? O2 sensor? MAF sensor? etc. Thanks FixUrNissan 03-25-2006, 05:45 PM It's been a whiel since you posted this..Still interested in help or did you get it fixed? mo6697 03-28-2006, 01:23 AM Yes, I still need help. It seems that I run the car for 5 min or si, it gets up to temp. then when I take my foot off the accelerator, it just dies. Sometimes up to 1/2 hr + to get to start again, onlt to die again. tinaslynn 03-31-2006, 02:34 PM I had a similar problem on a 90 stanza.. was intermittent of when it decided to die, but it would sit a few minutes and crank back up.. oddly enough it was the fuel pump.. replaced it a couple weeks ago and hasnt went dead yet.. (although it has other problems now) Good luck! j-cubs87 11-04-2008, 12:44 AM Hey! I have the same problem.....so what happened? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
